[mapserver-users] Premature end of script headers: mapserv
Shaz N geo.engineer123 at gmail.com
Sun Jan 10 00:31:56 EST 2010
Hi..
I added the new shapefiles to PostGIS using shp2pgsql etc and it was
successful. After that, in my mapfile, I included a new layer for each of
these shapefiles. What I copy-pasted in my mail was the layer that I added
in my mapfile.
I have included WMS metadata in the beginning of the mapfile:
WEB
    IMAGEURL "/tmp/"
    IMAGEPATH /tmp/ms_tmp/
      METADATA
        "wms_title"     "MOL"  ##required
        "wms_onlineresource" "....."   ##required
        "wms_srs"       "EPSG:2060"  ##recommended
     END
I was getting a good output using WMS request:
http://....../cgi-bin/mapserv?map=/data/..../t....map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getmap&layers=mol&STYLES=&SRS=epsg:2060&FORMAT=image/jpeg&WIDTH=600&HEIGHT=500&BBOX=332271.136,2800048.4565,335043.0915,2803465.287
As I kept adding new layers, I suddenly started getting an Internal server
error on my browser. When I checked the error log, it read: Premature end of
script headers: mapserv.
All the new layers were similar to each other, with only different "NAME"
and "DATA". But the internal server error would just not go unless I reduced
the total number of layers in my mapfile.
shp2img works fine and I get an output. What doesnt work is the WMS. Works
when I reduce the total number of layers in my mapfile. Is there a maximum
number of layers or classes that we can use? I use version 5.0
After reading the latest reply, I added WMS metadata to the "layers" also,
but WMS still doesnt work.
Please help.
Thanku v much..
On Sun, Jan 10, 2010 at 2:56 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> You talk about adding a shapefile but the layer definitions below are for
> PostGIS layer. Have you copy-pasted another layer or what? The main problem
> could be that the layer in your mail is missing entries for WMS metadata.
> Try reading and following the document at
> http://mapserver.org/ogc/wms_server.html.
> -Jukka Rahkonen-
> Shaz N wrote:
> > Hi users..
> > I have been adding a few new shapefiles to my existing map file. I am a
> facing a new problem since last evening. I added 9 shapefiles successfully
> and could view the map in the browser. While adding the 10th shapefile I
> got
> an error. All the new shapefiles are simple point shapefiles.
> Example: LAYER
>            NAME 'sc'
>            CONNECTIONTYPE postgis
>            CONNECTION " "
>            DATA "the_geom from sc"
>            TEMPLATE "dummy.html"
>            DEBUG ON
>            TYPE POINT
>            MAXSCALE 10000
>            MINSCALE 2000
>            STATUS DEFAULT
>            LABELITEM "name"
>            LABELCACHE ON
>            CLASS
>                  MAXSCALE 10000
>                  MINSCALE 2000
>            STYLE
>                  ANTIALIAS TRUE
>                  SYMBOL "square"
>                  SIZE 9
>                  COLOR 153 0 102
>                  OUTLINECOLOR 255 255 255
>            END #end style
>            LABEL
>                  ANGLE auto
>                  COLOR 153 0 102
>                  ANTIALIAS TRUE
>                  FONT vera_sans-bold
>                  TYPE TRUETYPE
>                  SIZE 9
>                  POSITION auto
>                  PARTIALS false
>                  BUFFER 1
>            END #end label
>            END#end class
> END #end layer
> This is the error from the error log:
> And this is what I got using WMS get map request on the browser:
> Internal Server Error
> The server encountered an internal error or misconfiguration and was unable
> to complete your request.
> Please contact the server administrator, [no address given] and inform them
> of the time the error occurred, and anything you might have done that may
> have caused the error.
> More information about this error may be available in the server error log.
> I checked the shapefile and map file for errors and couldn't find any. And
> mapserver has been installed correctly and has been working well. The
> problem only arises when I add the extra layer. It works well with all the
> existing ones.
> The map file works on my PHP map display page but when I try it using WMS
> it
> does not work.
> I use MapServer 5.0.
> Any help would be greatly appreciated.
> Thanks in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100110/fb413e2f/attachment-0001.html
