[mapserver-users] ka-Map - Mapserver - Map display problem.
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jun 27 23:51:09 EDT 2010
Ok, this is good, then it is likely something has changed in the PHP
mapscript. There is also a bug with the order of units which might be
tripping you up. Maybe one of the PHP/mapscript gurus has an idea on
what might be breaking ka-map on 5.6.3-1.
You might also check the ka-map list archives, I seem to remember
someone else running into this problem recently.
-Steve
Jaisen wrote:
> On 27 June 2010 22:33, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> Jaisen,
>> It would help to know what version of mapserver you are now running and what
>> you were running before?
> Now Version 5.6.3-1. The same available in the gfoss.itc.it repository.
> Previously, No idea :-(
>> You should also try something like:
>> shp2img -m /path/to/your/mapfile.map -o junk.png
>> and see if it reports any errors.
> This doesn't report any error. I get a map in png file format.
>> Recent versions of mapserver have had a change for security purposes which
>> now require most mapserver support files to have well know tags as the first
>> line(s) of the support file.
>> http://mapserver.org/development/rfc/ms-rfc-56.html
>> -Steve W
> Am attaching the report from one of my init.php file.
> Any help?
>> Jaisen wrote:
>>> Hi,
>>> I have ka-Map implementations in my Debian (Lenny) system, and were
>>> working pretty well. But after a system upgrade including mapserver,
>>> nothing is displayed in map window. The Coords are shown as: x: NaN y:
>>> NaN
>>> And inside the folders (for example):
>>> var/www/mykamap/htdocs/kacache/gmap/2500/Roads/def/t0/l0/meta
>>> a blank text file is seen, named:
>>> lock_-40_-40
>>> and inside the folder:
>>> /var/www/mykamap/htdocs/kacache/gmap/2500/Roads/def/t-1640448/l9770496/meta
>>> another blank file is seen named:
>>> lock_-1640488_9770456
>>> What exactly is this problem? Can anybody help me to resolve it?
>>> When I encountered this issue previously, I reinstalled the entire
>>> system to resolve. Now I want to know some other way to resolve
>>> this problem.
>>> Thanks in advance.
