[mapserver-users] Search function always ends with "no matching
results"
yadirosadi
yadi.rosadi at gmail.com
Wed Mar 3 00:16:19 EST 2010
Hi All,
I'm Yadi Rosadi I Have problem with search and queries on Kamap Using
Postgis the search-function always ends with "no matching results". if I
Using a shapefile, the search-function work
Any ideas why Kamap treats data from shapefiles and databases do different ?
This is the Layer :
LAYER
GROUP 'sd'
NAME 'sd'
TYPE POINT
CONNECTIONTYPE postgis
CONNECTION "host=localhost port=5432 user='postgres' password='postgres'
dbname='sigpilkada' "
DATA "the_geom FROM sd"
METADATA
'wms_title' 'sd '
"queryable" "true"
"searchfield" "nama_objek"
"fields" "nama_objek:alias1, sek_alamat:alias2"
END
STATUS ON
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
LABELITEM 'nama_objek'
CLASS
template "template.html"
NAME 'sd'
STYLE
SYMBOL 'logo-diknas2'
SIZE 15
END
LABEL
SIZE medium
COLOR 255 0 0
ANGLE 0
END
END
END
View this message in context: http://n2.nabble.com/Search-function-always-ends-with-no-matching-results-tp4665652p4665652.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
