[mapserver-users] Map file xsl transformation and regular expressions
Alexandre Soares asoares1 at gmail.com
Fri Mar 19 14:21:45 EDT 2010
When I transform my xml map file to a map file, my expressions that contain
a regular expression (the same is true for filters) are rendered with double
quotes (because the stylesheet has the quote="1" param for those templates).
Is there an intended way to achieve this? I know I could modify the
stylesheet to not quote those elements and then quote-wrap my value if I
need them (in case of string comparison).
Thank you!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100319/ef0e93dc/attachment.html
