[mapserver-users] Re: postgres fulltext search
mattmendick matt.mendick at pictometry.com
Wed May 5 12:25:45 EDT 2010
Andy-
Thanks a ton for taking a look at this for me. In looking around some more
talking about variable substitution, I found that I can do a FILTER like you
mentioned in the layer section of the mapfile. I could do a:
FILTER "city @@ ts_vector('%mycitysearch%')"
and then in the mapserver request url, add a &mycitysearch=new york, this
will work (I tried it using FILTER "city = '%mycitysearch%'", and it worked
perfectly. I don't have the full-text set up yet on my server, but i've done
it in the past.)  It's too bad I can't do it with the normal PropertyIsLike
syntax, but it seems that if I wanted to hack up the code for our own
installation, I could replace the sql building code with my own.
Thanks very much for your help, you've answered a lot of my questions!
-Matt
View this message in context: http://osgeo-org.1803224.n2.nabble.com/postgres-fulltext-search-tp5009033p5009786.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
