[mapserver-users] Colorrange in map file
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri May 14 16:02:29 EDT 2010
Antonio Ruggiero wrote:
> ----- Original Message ----- From: "TC Haddad" <tchaddad at gmail.com>
> To: "Antonio Ruggiero" <a.ruggiero at gmail.com>
> Sent: Friday, May 14, 2010 4:52 PM
> Subject: Re: [mapserver-users] Colorrange in map file
>> separate them into different classes...
> Thanx i tried ths and other ways and it is still not working, i found
> this RFC
> http://mapserver.org/development/rfc/ms-rfc-6.html
> Allows multiple COLORANGES to be applied to a single layer (i.e.
> Red->Yellow and Yellow->Green to make a contiguous Reg->Yellow->Green).
> Seems to be in the Todo List
Antonio,
I have done some testing with MapServer 5.6.3, and indeed you are
correct: multiple color ranges for a single data file are not currently
supported. If I were you I would enter a comment with your findings
into the existing ticket for this
(http://trac.osgeo.org/mapserver/ticket/1305) and poke the developers
that way.
I'll make sure the new doc contains this limitation.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
