[mapserver-users] map file paths
Wim Vanbelle wimvanbelle at gmail.com
Thu Nov 4 03:41:09 EDT 2010
I'm pretty sure you can use the rewrite module in IIS to achieve what you
need. I use it myself for a couple of REST webservices. Do note that I am
using IIS 7.
Take a look here :
http://learn.iis.net/page.aspx/460/using-the-url-rewrite-module/
On 4 November 2010 07:53, Waberzeck, Thomas <
Thomas.Waberzeck at liag-hannover.de> wrote:
> Jukka Rahkonen wrote:
> > P Kishor wrote:
> > > So you have 15 copies of the binary floating around on your computer.
> > > What a nightmare. If you upgrade, you have to make 15 copies of the
> > > new version and replace the old version.
> > > What would happen when you publish the 150th geologic map?
> > > Use a single binary, and use a wrapper (or the env variable) to get
> > > the right query.
> > I do not believe there are handy wrappers for Windows and the only way
> > I have been able to get SetEnvIf to work is to make copies of
> > mapserv.exe with different names. I maintain a batch file about our
> > services with lines like "COPY mapserv.exe WMS_service1" etc. and then
> > I only need to run the batch after update and publishing the 150th
> > service does not change anything.
> If you have php it's quite easy to write a small wrapper for it. See
> http://www.mapserver.org/ogc/mapscript.html#php-example so the only thing
> to do is to write the wrappers once and you have a single setup of
> Mapserver.
> Thomas
> BTW: The Example should be updated - I think php_mapscript_4.10.0.dll is
> out of date. The name of the .dll is just php_mapscript.dll.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101104/fb680e42/attachment.html
