[mapserver-users] Trouble with OGR output and writing to temppath
John Cartwright john.c.cartwright at comcast.net
Sun Dec 4 15:34:16 EST 2011
Thanks for the suggestion, but I ran across that ticket earlier and setting TEMPPATH didn't address my problem. It does direct the temporary files to the desired location I still see:
  <ServiceException code="NoApplicableCode" locator="mapserv">
msOGRWriteFromQuery(): General error message. Failed to open result file &#39;/Library/WebServer/Documents/output/4edbd893_e3b_0/result.csv&#39;.
  </ServiceException>
</ServiceExceptionReport>
in my output file.
--john
On Dec 4, 2011, at 10:06 AM, Rahkonen Jukka wrote:
> Hi,
> Part of the problem can be solved by setting TEMPPATH at MAP - WEB level.  See http://trac.osgeo.org/mapserver/ticket/3354 and recent http://trac.osgeo.org/mapserver/ticket/4103.  That makes Mapserver to use the desired directory as a target for the temporary stuff.  However, there seems still be something that fails at least for me.
> Could you try to add TEMPPATH to your mapfile and see if you still get the same error?
> -Jukka-
> ________________________________________
> John Cartwright wrote:
>> This sounds like the same trouble I had and filed a ticket (http://trac.osgeo.org/mapserver/ticket/4085).  I haven't yet found a workaround.
> --john
> On Dec 4, 2011, at 3:29 AM, Rahkonen Jukka wrote:
>> Hi,
>> I have troubles with getting the ORG output to work.
>> I have configured CVS ouput like this
>> OUTPUTFORMAT
>> NAME "CSV"
>> DRIVER "OGR/CSV"
>> MIMETYPE "text/csv"
>> FORMATOPTION "LCO:GEOMETRY=AS_WKT"
>> FORMATOPTION "STORAGE=filesystem"
>> FORMATOPTION "FORM=simple"
>> FORMATOPTION "FILENAME=result.csv"
>> END
>> I have set TEMPPATH in the MAP/WEB
>> WEB
>>      TEMPPATH "/usr/temp/"
>> /usr/temp directory has 0777 permissions.  Mapserver can write error.log file into that directory without troubles.
>> WFS works normally with outputformats GML2 and GML3. However, WFS requests with CSV outputformat fails and I am getting error messages like this:
>> msOGRWriteFromQuery(): General error message. Failed to open result file '/usr/temp/4edb45fd_707c_0/result.csv'.
>> Error.log file is also listing all the features and all the attributes so the query itself is successful.
>> I am trying this with Ubuntu server and Mapserver version is 6.0.1.  It is also odd that I am sure that I did manage to get valid zipped shapefiles out from this same server a couple of days ago but now all that I am getting back is empty zipfile. Error.log does not report about any error in this case.
>> Any suggestions what to try next or what to do for finding the ultimate reason for the error?
>> -Jukka Rahkonen-
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
