[mapserver-users] msShapefileOpen(): Unable to access file
Brent Fraser
bfraser at geoanalytic.com
Tue Jul 12 09:59:05 EDT 2011
Dave,
I've had good success rendering DGN files referenced in a TILEINDEX
(http://lists.osgeo.org/pipermail/mapserver-users/2010-December/067444.html).
Try adding ".shp" to the end of your TILEINDEX:
TILEINDEX "index_dg.shp"
as OGR handles the files differently than Mapserver's native shapefile
mechanism.
Best Regards,
Brent Fraser
On 7/12/2011 6:25 AM, Dave Chetan wrote:
> Dear Jukka,
> Yes, I am able to publish single DGN.
> But when I go for tiled dgn, I have error.
> Regards,
> Dave C.
> On 7/12/11, Rahkonen Jukka<Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>> I have never played with DGN files with Mapserver. I would blindly follow
>> the documents and try first with just one DGN file as in
>> http://mapserver.org/input/vector/dgn.html
>> and forward next to ogrtileindex as in
>> http://mapserver.org/input/vector/ogr.html
>> Perhaps there is something important in the syntax of TILEINDEX given in the
>> following example.
>> LAYER
>> NAME "ogr_points"
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> TILEINDEX "PIP_ogr_tiles.shp,0"
>> -Jukka Rahkonen-
>> ________________________________________
>> Lähettäjä: Dave Chetan [csdave4u at gmail.com]
>> Lähetetty: 12. heinäkuuta 2011 14:58
>> Vastaanottaja: Rahkonen Jukka
>> Kopio: mapserver-users at lists.osgeo.org
>> Aihe: Re: [mapserver-users] msShapefileOpen(): Unable to access file
>> Hi Rahkonen,
>> Thanks for the prompt reply..!!
>> If I add
>> CONNECTIONTYPE OGR
>> in the Layer Tag, then the error is
>> 7/12/2011 4:29:20 PM|msDrawMap(): Image handling error. Failed to draw
>> layer named 'DGN'.;msOGRFileOpen(): OGR error. Open failed for OGR
>> connection in layer `DGN'. File not found or unsupported format.
>> 7/12/2011 4:29:20 PM| at OSGeo.MapServer.mapObj.draw()
>> at MapCreator.Controls.MapControl.RefreshMap()
>> Regards,
>> Dave C.
>>> Hi,
>>> I guess that Mapserver is seaching for shapefiles as default. Read the
>>> document http://mapserver.org/input/vector/ogr.html and have a try with
>>> CONNECTIONTYPE=OGR.
>>> -Jukka Rahkonen
>>> Dave Chetan wrote:
>>> Hi,
>>> I am publishing DGN data using tile option. I am getting error
>>> "msShapefileOpen(): Unable to access file".
>>> Following are the details of Input data, steps executed and error log.
>>> Please, if anyone can help in resolving the issue.
>>> Source files are DGN
>>> D:\Tile\DGN\Final\1.dgn
>>> D:\Tile\DGN\Final\3.dgn
>>> D:\Tile\DGN\Final\5.dgn
>>> D:\Tile\DGN\Final\7.dgn
>>> D:\Tile\DGN\Final\9.dgn
>>> Step1)-
>>> Creation of Index tile
>>> ogrtindex.exe d:\Tile\DGN\Final\index_dgn.shp d:\Tile\DGN\Final\*.dgn
>>> Ogrtindex created "index_dgn.shp" index file
>>> Step2)-
>>> Map file
>>> EXTENT 699218.75297987 2251967.57943806 755021.241547886
>>> 2291053.54827586
>>> SHAPEPATH "D:\Tile\DGN\Final"
>>> LAYER
>>> NAME "DGN"
>>> STATUS ON
>>> TILEINDEX "index_dgn"
>>> TILEITEM "location"
>>> TYPE LINE
>>> UNITS METERS
>>> CLASS
>>> NAME "DGN"
>>> STYLE
>>> ANGLE 360
>>> COLOR 240 215 209
>>> SYMBOL "LineDash"
>>> WIDTH 1
>>> END
>>> END
>>> END
>>> Error
>>> 7/12/2011 4:21:33 PM|msDrawMap(): Image handling error. Failed to draw
>>> layer named 'DGN'.;msTiledSHPOpenFile(): Shapefile error. Unable to
>>> open a single tile to use as a template in layer
>>> DGN.;msShapefileOpen(): Unable to access file.
>>> (d:\Tile\DGN\Final\9.dgn,0);msShapefileOpen(): Unable to access file.
>>> (d:\Tile\DGN\Final\7.dgn,0);msShapefileOpen(): Unable to access file.
>>> (d:\Tile\DGN\Final\5.dgn,0);msShapefileOpen(): Unable to access file.
>>> (d:\Tile\DGN\Final\3.dgn,0);msShapefileOpen(): Unable to access file.
>>> (d:\Tile\DGN\Final\1.dgn,0);msShapefileOpen(): Unable to access file.
>>> 7/12/2011 4:21:33 PM| at OSGeo.MapServer.mapObj.draw()
>>> In the Layer Tag if I add following line
>>> CONNECTIONTYPE OGR
>>> the error is
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
