[mapserver-users] defresolution & resolution in 6.0
thomas bonfort thomas.bonfort at gmail.com
Tue Jul 19 02:56:09 EDT 2011
I still haven't been able to reproduce the issue with my simple
testcase, so please attach the complete mapfile that triggers this to
the bugreport.
thomas
On Tue, Jul 19, 2011 at 08:37, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> On Mon, Jul 18, 2011 at 21:31, Richard Greenwood
> <richard.greenwood at gmail.com> wrote:
>> thomas,
>> Thank you for your reply. This link should produce an image with lines rendered:
>> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=72&map.resolution=144
>> This is the same except with map.resolution=100 and lines are not
>> rendered, image is blank:
>> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=72&map.resolution=100
>> When map.defresolution=72, any value for map.resolution between 73 and
>> 143 fails to render lines. Similarly when map.defresolution=10, any
>> value for map.resolution between 11 and 19 fails to render lines.
>> You can easily change defresolution and resolution in the URL yourself
>> to see the behavior.
>> If you consider this a bug I am happy to file a ticket, but I'd like
>> another set of eyes on it before I do so.
> This definitely seems like a bug, go ahead and file a ticket !
> thanks,
> thomas
>> Thank you,
>> Rich
>> On Mon, Jul 18, 2011 at 11:52 AM, thomas bonfort
>>> Richard,
>>> I was also unable to reproduce your issue (see the similar titled
>>> thread initiated by Mike Smith), using the
>>> msautotest/renderers/polygon-as-line.map
>>> please submit a self-contained test-case where the issue can be reproduced.
>>> thanks,
>>> thomas
>>> On Sun, Jul 17, 2011 at 21:35, Richard Greenwood
>>>> When I use defresolution & resolution in MapServer 6.0 on lines with a
>>>> width of 1 nothing is displayed. Specifically I am using:
>>>>   map.defresolution=96&map.resolution=144
>>>> on a polygon layer defined as:
>>>>  CLASS
>>>>    NAME "Lot and Parcel Lines"
>>>>    STYLE
>>>>      OUTLINECOLOR 255 0 0
>>>>      WIDTH 1
>>>>    END
>>>>  END
>>>> Example (works):
>>>> Example, with defresolution & resolution doesn't work:
>>>> http://maps.hscounty.com/cgi-bin/mapserv.exe?map=MAP_15_MAIN&layers=ownership&mode=map&map.defresolution=96&map.resolution=144
>>>> Any insight would be appreciated.
>>>> Thanks,
>>>> Rich
>>>> Richard Greenwood
>>>> www.greenwoodmap.com
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Richard Greenwood
