[mapserver-users] font support problem
William Kyngesburye woklist at kyngchaos.com
Wed Jun 1 10:11:34 EDT 2011
Freetype is not the problem.  I already figured it out - my gd font support needs -liconv and configure is not adding it to the gd test.  It looks like the mapserver configure doesn't get the libs from the gdlib-config script but makes a common guess.
I thought I had this working in the past, but it's possible I only recently added iconv support to my gd. I forget.
On Jun 1, 2011, at 8:49 AM, Stephen Woodbridge wrote:
> ./configure can not find your truetype font includes and/or libs. You need to make sure you have the truetype package installed on Linux this is called something like freetype2. On my debian system:
> ls /usr/include/freetype2/freetype/
> config        ftcid.h     ftimage.h   ftmodapi.h  ftsnames.h  ftxf86.h
> freetype.h    fterrdef.h  ftincrem.h  ftmoderr.h  ftstroke.h  t1tables.h
> ftbbox.h      fterrors.h  ftlcdfil.h  ftotval.h   ftsynth.h   ttnameid.h
> ftbdf.h       ftgasp.h    ftlist.h    ftoutln.h   ftsystem.h  tttables.h
> ftbitmap.h    ftglyph.h   ftlzw.h     ftpfr.h     fttrigon.h  tttags.h
> ftcache.h     ftgxval.h   ftmac.h     ftrender.h  fttypes.h   ttunpat.h
> ftchapters.h  ftgzip.h    ftmm.h      ftsizes.h   ftwinfnt.h
> ls /usr/lib/libfreetype.*
> /usr/lib/libfreetype.a   /usr/lib/libfreetype.so.6
> /usr/lib/libfreetype.la  /usr/lib/libfreetype.so.6.3.18
> -Steve W
> On 6/1/2011 9:44 AM, William Kyngesburye wrote:
>> It would help if I turned off the find words option ;)  There it is in configure, I just need to figure out why it was disabled.
>> On Jun 1, 2011, at 8:40 AM, William Kyngesburye wrote:
>>> Something has killed my font support in MapServer in the compilation stage.
>>> I'm getting a "Keyword FONT is not valid without TrueType font support" error at runtime.  It looks like font support is conditionalized on USE_GD_TTF or USE_GD_FT, but I can't figure out where this is set in configuration.  I don't see those in the GD sources either.
>>> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "Time is an illusion - lunchtime doubly so."
>>> - Ford Prefect
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> - Ford Prefect
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
The equator is so long, it could encircle the earth completely once.
