[mapserver-users] font support problem
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jun 1 11:24:27 EDT 2011
When you get a chance please write a bug against this issue. It seems
that there are a few things that need to be fixed:
1. error message is wrong and misleading
2. configure is not finding the libraries
3. configure is not detecting a missing library (iconv) and disabling
freetype if the missing lib is required.
4. freetype without iconv should be ok unless this is a new requirement
5. doc needs to be updated as required
Also I would think the a missing -liconv should cause a fatal link error
in make.
Thanks,
-Steve
On 6/1/2011 10:11 AM, William Kyngesburye wrote:
> Freetype is not the problem. I already figured it out - my gd font
> support needs -liconv and configure is not adding it to the gd test.
> It looks like the mapserver configure doesn't get the libs from the
> gdlib-config script but makes a common guess.
> I thought I had this working in the past, but it's possible I only
> recently added iconv support to my gd. I forget.
> On Jun 1, 2011, at 8:49 AM, Stephen Woodbridge wrote:
>> ./configure can not find your truetype font includes and/or libs.
>> You need to make sure you have the truetype package installed on
>> Linux this is called something like freetype2. On my debian
>> system:
>> ls /usr/include/freetype2/freetype/ config ftcid.h
>> ftimage.h ftmodapi.h ftsnames.h ftxf86.h freetype.h
>> fterrdef.h ftincrem.h ftmoderr.h ftstroke.h t1tables.h ftbbox.h
>> fterrors.h ftlcdfil.h ftotval.h ftsynth.h ttnameid.h ftbdf.h
>> ftgasp.h ftlist.h ftoutln.h ftsystem.h tttables.h
>> ftbitmap.h ftglyph.h ftlzw.h ftpfr.h fttrigon.h
>> tttags.h ftcache.h ftgxval.h ftmac.h ftrender.h
>> fttypes.h ttunpat.h ftchapters.h ftgzip.h ftmm.h
>> ftsizes.h ftwinfnt.h
>> ls /usr/lib/libfreetype.* /usr/lib/libfreetype.a
>> /usr/lib/libfreetype.so.6 /usr/lib/libfreetype.la
>> /usr/lib/libfreetype.so.6.3.18 /usr/lib/libfreetype.so
>> -Steve W
>> On 6/1/2011 9:44 AM, William Kyngesburye wrote:
>>> It would help if I turned off the find words option ;) There it
>>> is in configure, I just need to figure out why it was disabled.
>>> On Jun 1, 2011, at 8:40 AM, William Kyngesburye wrote:
>>>> Something has killed my font support in MapServer in the
>>>> compilation stage.
>>>> I'm getting a "Keyword FONT is not valid without TrueType font
>>>> support" error at runtime. It looks like font support is
>>>> conditionalized on USE_GD_TTF or USE_GD_FT, but I can't figure
>>>> out where this is set in configuration. I don't see those in
>>>> the GD sources either.
>>>> ----- William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "Time is an illusion - lunchtime doubly so."
>>>> - Ford Prefect
>>>> _______________________________________________ mapserver-users
>>>> mailing list mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> - Ford Prefect
> The equator is so long, it could encircle the earth completely once.
