[mapserver-users] font support problem
William Kyngesburye
woklist at kyngchaos.com
Wed Jun 1 11:52:16 EDT 2011
Freetype is found. Iconv is found. GD is found. gdImageStringFT test fails because it doesn't try with iconv.
I do see a test for if GD needs iconv in configure, but for some reason it's not getting to this test for me... I'll look into it more later this evening when I have time.
On Jun 1, 2011, at 10:24 AM, Stephen Woodbridge wrote:
> When you get a chance please write a bug against this issue. It seems that there are a few things that need to be fixed:
> 1. error message is wrong and misleading
> 2. configure is not finding the libraries
> 3. configure is not detecting a missing library (iconv) and disabling freetype if the missing lib is required.
> 4. freetype without iconv should be ok unless this is a new requirement
> 5. doc needs to be updated as required
> Also I would think the a missing -liconv should cause a fatal link error in make.
> Thanks,
> -Steve
> On 6/1/2011 10:11 AM, William Kyngesburye wrote:
>> Freetype is not the problem. I already figured it out - my gd font
>> support needs -liconv and configure is not adding it to the gd test.
>> It looks like the mapserver configure doesn't get the libs from the
>> gdlib-config script but makes a common guess.
>> I thought I had this working in the past, but it's possible I only
>> recently added iconv support to my gd. I forget.
>> On Jun 1, 2011, at 8:49 AM, Stephen Woodbridge wrote:
>>> ./configure can not find your truetype font includes and/or libs.
>>> You need to make sure you have the truetype package installed on
>>> Linux this is called something like freetype2. On my debian
>>> system:
>>> ls /usr/include/freetype2/freetype/ config ftcid.h
>>> ftimage.h ftmodapi.h ftsnames.h ftxf86.h freetype.h
>>> fterrdef.h ftincrem.h ftmoderr.h ftstroke.h t1tables.h ftbbox.h
>>> fterrors.h ftlcdfil.h ftotval.h ftsynth.h ttnameid.h ftbdf.h
>>> ftgasp.h ftlist.h ftoutln.h ftsystem.h tttables.h
>>> ftbitmap.h ftglyph.h ftlzw.h ftpfr.h fttrigon.h
>>> tttags.h ftcache.h ftgxval.h ftmac.h ftrender.h
>>> fttypes.h ttunpat.h ftchapters.h ftgzip.h ftmm.h
>>> ftsizes.h ftwinfnt.h
>>> ls /usr/lib/libfreetype.* /usr/lib/libfreetype.a
>>> /usr/lib/libfreetype.so.6 /usr/lib/libfreetype.la
>>> /usr/lib/libfreetype.so.6.3.18 /usr/lib/libfreetype.so
>>> -Steve W
>>> On 6/1/2011 9:44 AM, William Kyngesburye wrote:
>>>> It would help if I turned off the find words option ;) There it
>>>> is in configure, I just need to figure out why it was disabled.
>>>> On Jun 1, 2011, at 8:40 AM, William Kyngesburye wrote:
>>>>> Something has killed my font support in MapServer in the
>>>>> compilation stage.
>>>>> I'm getting a "Keyword FONT is not valid without TrueType font
>>>>> support" error at runtime. It looks like font support is
>>>>> conditionalized on USE_GD_TTF or USE_GD_FT, but I can't figure
>>>>> out where this is set in configuration. I don't see those in
>>>>> the GD sources either.
>>>>> ----- William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "Time is an illusion - lunchtime doubly so."
>>>>> - Ford Prefect
>>>>> _______________________________________________ mapserver-users
>>>>> mailing list mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> - Ford Prefect
>> The equator is so long, it could encircle the earth completely once.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
