[mapserver-users] SLD with filter
Daniel Degasperi daniel.degasperi at r3-gis.com
Wed Jun 1 11:25:46 EDT 2011
Ok, ticket (with test data) created at
http://trac.osgeo.org/mapserver/ticket/3902
Am 31/05/2011 19:35, schrieb Yewondwossen Assefa:
> Daniel,
>  I just did a quick test with 5.6.x (svn) and a postgis layer using
> the metadata but could not reproduce a crash. If it is something I can
> reproduce using some test map/data/filter, I will investigate. You can
> either send them to me or attache it to a trac bug.
> best regards
> On 31/05/2011 10:25 AM, Daniel Degasperi wrote:
>> Ok, with the metadata tag described below mapserver does not
>> reprocude this error, but it throws a segfault.
>> I've put the coredump online: http://www.r3-gis.com/core.333.gz
>> Best regards,
>> Daniel
>> Am 31/05/2011 14:37, schrieb Yewondwossen Assefa:
>>> Hi Daniel,
>>>  You could possibly try to set on the layer a metadata for the type
>>> of your field to force it to string: something like
>>>   metadata
>>>      "ows_localita_type" "Character"
>>>     end
>>> regards,
>>> On 31/05/2011 8:26 AM, Daniel Degasperi wrote:
>>>> Hi,
>>>> I've a problem with following filter:
>>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>>> <ogc:PropertyIsEqualTo matchCase="true">
>>>> <ogc:PropertyName>localita</ogc:PropertyName>
>>>> <ogc:Literal>1.102</ogc:Literal>
>>>> </ogc:PropertyIsEqualTo>
>>>> </ogc:Filter>
>>>> Output:
>>>> <?xml version="1.0" encoding="ISO-8859-1"?>
>>>> <ows:ExceptionReport
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>> xmlns:ows="http://www.opengis.net/ows" version="1.1.0"
>>>> language="en-US" xsi:schemaLocation="http://www.opengis.net/ows
>>>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
>>>> <ows:Exception exceptionCode="mapserv" locator="NoApplicableCode">
>>>> <ows:ExceptionText>msWFSGetFeature(): WFS server error.
>>>> FLTApplyFilterToLayer() failed
>>>> msPostGISLayerWhichShapes(): Query error. Error (ERROR:  operator
>>>> does not exist: text = numeric
>>>> LINE 1: ...6966392 4130435.36164853))',32632) and ( (localita=
>>>> 1.102) )
>>>> HINT:  No operator matches the given name and argument type(s). You
>>>> might need to add explicit type casts.
>>>> ) executing query: select
>>>> "gc_objid","di_id","localita","di_name_1",encode(AsBinary(force_collection(force_2d("the_geom")),'NDR'),'hex')
>>>> as geom,"gc_objid" from (SELECT  __data__.di_id as
>>>> gc_objid,__data__.the_geom,
>>>> __data__.di_id,__data__.localita,__data__.di_name_1 FROM
>>>> geo.district_area AS __data__) AS foo where the_geom &amp;&amp;
>>>> GeomFromText('POLYGON((-393764.596966392
>>>> 4130435.36164853,-393764.596966392 5936656.6234314,1412456.59042116
>>>> 5936656.6234314,1412456.59042116 4130435.36164853,-393764.596966392
>>>> 4130435.36164853))',32632) and ( (localita= 1.102)
>>>> )</ows:ExceptionText>
>>>> </ows:Exception>
>>>> </ows:ExceptionReport>
>>>> It seems that the value 1.102 is not quoted. Should I add the
>>>> attribute xs:type="string" to the literal node or use the
>>>> PropertyIsLike condition?
>>>> I'm using MapServer 5.6.6
>>>> Best regards,
>>>> Daniel
Daniel Degasperi R3 GIS Srl - GmbH www.r3-gis.com
