[mapserver-users] Mapserver 6.0 regex
Tamas Szekeres szekerest at gmail.com
Tue Jun 21 13:34:49 EDT 2011
Hi Chris,
The cluster->filter can only accept mapserver expressions, filteritem and
regex at layer level does not affect this setting.
However I consider the layer level filter should probably work, could you
file a ticket by adding some test data and a mapfile example?
Best regards,
Tamas
2011/6/21 Chris Green <chris.green at ibstv.co.uk>
> Hi Steve****
> That’s a very constructive suggestion. With no mapscript involved and with
> the mapfile set up without a  cluster class I added into the layer section:
>   FILTERITEM ‘Groups’****
>   FILTER /group4/****
> This worked: I got only group4 features.****
> Then I changed the mapfile to use a cluster class, with no filter: this
> worked, I got all features clustered and with labels showing the
> FeatureCount for each cluster. ****
> Then I inserted the same FILTERITEM and FILTER into the layer as above, and
> there is no output. Nada.****
> So it seems to be not a mapscript problem, but some kind of conflict
> between clustering and filtering in Mapserver?****
> Chris****
> *From:* Lime, Steve D (DNR) [mailto:steve.lime at state.mn.us]
> *Sent:* 21 June 2011 17:09
> *To:* Chris Green; mapserver-users at lists.osgeo.org
> *Subject:* RE: [mapserver-users] Mapserver 6.0 regex****
> Hmmm… A plain ‘ol regex expression did not change between 5.6 and 6.0, so
> this is still valid:****
>   FILTERITEM ‘myitem’****
>   FILTER /myregex/****
> Where regex’s changed is *inside* logical expressions:****
>   FILTER (‘[myitem]’ ~= /myregex/) becomes FILTER (‘[myitem]’ ~ ‘myregex’)
> There are regression tests for these cases (query/filters.map) so I’m
> pretty sure MapServer proper is working ok. You might try setting the filter
> and filteritem directly in the mapfile see if that works. If it does then
> it’s likely a problem with PHP/MapScript.****
> Steve****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Chris Green
> *Sent:* Monday, June 20, 2011 12:39 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Mapserver 6.0 regex****
> I have one (hopefully the last!) problem with migrating from Mapserver 4.6
> to 6.0, this time over the use of regex.****
> Using Mapscript  on a Fedora platform I have been setting a filter in this
> manner:****
> $map=newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");****
> $layer1=$map->getLayerByName("test1");****
> $layer1->set("filteritem", "Attribute1");****
> $layer1->setFilter("/target/");****
> This worked fine, but not anymore.  I see in the migration guide that a
> regex should now be delineated as a string so I assume that “/target/”
> should become “target”. But that doesn’t work either.****
> I am wondering if part of the problem is that as well as going from
> Mapserver 4.6 to 5.0 I also changed from Fedora to Ubuntu 10.04, and I see
> from the Mapserver documentation on Expressions that the OS may affect regex
> operation.****
> Am I missing something obvious here?   I am really tired of going in
> circles over this…****
> Chris****
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110621/865079a9/attachment.html
