[mapserver-users] Mapserver 6 WMS / PostGIS Problem
Daniel Morissette dmorissette at mapgears.com
Fri May 20 16:07:28 EDT 2011
A few guesses/hints...
Perhaps enable DEBUG in your postgis layer, and compare the SQL query
that is generated by shp2img and by the WMS request. What are the
differences? What if you try to run the same SQL query at the psql
prompt or in pgadmin?
Which version of MapServer are you upgrading from? Did the same WMS
request work in that older version?
Daniel
On 11-05-20 01:35 PM, Rob McCulley wrote:
> I’m trying to upgrade to Mapserver 6, but I’m having some difficulty
> with my PostGIS layers. I’ve made all of the style / symbology changes
> required by Version 6, as well as adding the “wms_enable_request” “*”
> line to the WEB section. My raster and shapefile layers work fine. Any
> mapfile that has a postgis layer won’t work at all. On a GetCapabilities
> request, the cgi executable just churns away at 100% CPU usage, but
> never produces a result. A GetMap request produces the same result. I
> running on windows 7, and I’ve tried the binaries from both MS4W as well
> as the ones available from Tamas. I also tried to roll my own, but all
> returned the same results.
> It doesn’t appear to be a problem with the mapfile or the postgis
> access, because shp2img produces images just fine. It’s only WMS
> requests that don’t work.
> An example mapfile is below. It works fine with shp2img, but hangs on
> any WMS request.
> Thanks in advance,
> Rob McCulley
> Mapfile:
> MAP
> NAME "WMS-test"
> STATUS ON
> SIZE 800 800
> SYMBOLSET symbol.sym
> EXTENT 497444 5856659 566947 5971683
> UNITS METERS
> WEB
> IMAGEPATH "/Program Files (x86)/Apache Software
> Foundation/Apache2.2/htdocs/tmp/"
> IMAGEURL "/tmp/"
> METADATA
> "ows_enable_request" "*"
> "wms_title" "WMS Demo Server"
> "wms_onlintresource" "http://localhost/cgi-bin/mapserv.exe?map=wmstest.map&"
> "wms_srs" "EPSG:26912"
> END
> END
> CONFIG "PROJ_LIB" "C:/proj/nad/"
> PROJECTION
> "init=epsg:26912"
> END
> LAYER
> NAME "parcels"
> METADATA
> "wms_title" "Parcels"
> END
> TYPE POLYGON
> STATUS OFF
> CONNECTION "host=gpsserver dbname=CVR user=***** password=*****"
> CONNECTIONTYPE postgis
> DATA "shape FROM (SELECT id AS oid, geom AS shape FROM titles WHERE
> county = 1) AS foo USING UNIQUE oid USING SRID=26912"
> PROJECTION
> "init=epsg:26912"
> END
> CLASS
> NAME "Parcels"
> STYLE
> OUTLINECOLOR 0 0 0
> END
> END
> END
> END
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
