[mapserver-users] Sporadically "Cannot create OCI handlers"
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Tue Oct 25 05:13:29 PDT 2011
Make sure to verify your connection string (to any database) first
through an ogrinfo command, then once that returns properly focus on
your mapfile.
If I run into problems with the connection string/query in ogrinfo, then
I usually focus on the database, testing with psql (Postgres) or sqlplus
(Oracle) commandline utilities...then again once the connection/query is
established there then I move to ogrinfo, then to the mapfile (with
shp2img).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-10-25 9:00 AM, Meine Toonen wrote:
> Hi list,
> I have a layer defined in a mapfile, using an oracle connection. Most of
> the time this works, but sometimes I get an error.
> The Error:
> msDrawMap(): Image handling error. Failed to draw layer named
> 'telvakken_l'.; msOracleSpatialLayerOpen(): OracleSpatial error. Cannot
> create OCI Handlers. Connection failed. Check the connection string.
> Seems to me the connection string is fine, because it does work. Maybe
> you can help me? The layer is defined below:
> The Mapfile:
> LAYER
>      NAME "telvakken_l"
>      DATA "SHAPE from (select OBJECTID,TELPUNT,NAAM_WEGVA,BEHEERDER,BEGIN_HMP,EIND_HMP,WEGN,SHAPE from telvakken_l) using UNIQUE OBJECTID SRID 90112"
>      TYPE LINE
>      CONNECTIONTYPE oraclespatial
>      CONNECTION "UN/PW at DB"
>      PROCESSING "CLOSE_CONNECTION=DEFER"
>      METADATA
> 	ows_title "Verkeerstelvakken"
>     	ows_extent "150000 296000 223454 435000"
>     	ows_abstract "Verkeerstelvakken"
>     	gml_include_items "all"
>     	gml_featureid "OBJECTID"
>     	ows_metadataurl_format "text/xml"
>     	ows_metadataurl_href "http://acceptatie.prvlimburg.nl/mapfiles/infrastructuur/metadata/telvakken_l.xml"
>     	ows_metadataurl_type "FGDC"
>      END #METADATA
>      DUMP TRUE
>      OPACITY 85
>      STATUS on
>      UNITS METERS
>      TEMPLATE "/var/www/html/blank.html"
>      SIZEUNITS PIXELS
>      MINSCALEDENOM 0
>      MAXSCALEDENOM 10000000
>      TOLERANCE 3
>      TOLERANCEUNITS PIXELS
> PROJECTION
>         "init=epsg:28992"
> END #PROJECTION
>    CLASS
>          NAME 'Verkeerstelvakken'
>           STYLE
>           WIDTH 2
>           COLOR 255 31 0
>        END #STYLE
>    END #CLASS
> END #LAYER
> Thanks in advance.
> Kind regards,
> Meine Toonen
> B3Partners BV
> Tel: 030 214 2083
More information about the MapServer-users
