[mapserver-users] Re: Can't get Tinyows WFS Layer to show in OpenLayer
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Fri Feb 3 00:16:47 EST 2012
Did you mention what version you were using? Perhaps it is version 0.9.0 which was indeed using keywords "prefix" and "server". Change into ns_prefix adn ns_uri was done last spring http://tinyows.org/trac/changeset/343
If that is the case I would recommend updating your TinyOWS to the current release canditate.
-Jukka Rahkonen-
________________________________________
 Wang, Ya wrote:
> Hello All,
> The problem got solved finally. It seems all I need to do is to add two more lines into my TinyOWS configuration.  Maybe fixing the PythonPath helped as well. But this change is what really makes a difference.
Before (not working):
<layer retrievable="1"
         writable="0"
         ns_prefix="tows"
         ns_uri="http://myserver:8080/"
           schema="transit"
         name="lrtstops"
         srid="2227"
         title="LRT Stops" />
After (working now):
         writable="0"
        ns_prefix="tows"
        prefix="tows"
         server="http://myserver:8080/"
       schema="transit"
       name="lrtstops"
       srid="2227"
I was relieved of the frustration I have been suffering during the past two days. Thanks everyone.
Ya
___________________________________________________________________________
Message: 5
Date: Thu, 2 Feb 2012 08:57:52 +0100
From: Olivier Courtin <olivier.courtin at gmail.com>
Subject: Re: [mapserver-users] Can't get Tinyows WFS Layer to show in
        OpenLayer
To: "mapserver-users at lists.osgeo.org"
        <mapserver-users at lists.osgeo.org>
Message-ID:
        <CAD+A4Nz+q5m4DxjxFMRPAygx9c7eryfU705F330vXE+qRGgeXg at mail.gmail.com>
Content-Type: text/plain; charset="windows-1252"
On Wed, Feb 1, 2012 at 7:33 PM, Wang, Ya <Ya.Wang at vta.org> wrote:
 I am a newbie of mapserver and other online mapping technologies.
> Recently, I have been struggling to load a TinyOWS WFS Layer to an
> OpenLayers map.  I set up proxy.cgi, which works fine. I checked TinyOWS
> using command ?tinyows ?check?, which also seems to be working. The page
> http://.../cgi-bin/tinyows.exe?service=wfs&request=getCapabilities&version=1.1.0&typename=tows:lrtstopsdoesn?t return any error either.  I can also load a mapserver WMS layer
> into the OpenLayers Map with no problem. However, no feature from the WFS
> layer would show in the OpenLayers map.  Since both the WMS and WFS layers
> are of the same projection, which is EPSG:2227, I assume that the
> misspecification of projection is not likely to be the caprice here.   The
> following is the JavaScript I used and the response returned. Could someone
> help me find out what I did wrong? Many thanks in advance!
Several questions related to your issue:
- What TinyOWS version do you use ?
- What happen if you use QGIS as WMS/WFS client rather than OpenLayers ?
- Could you activate TinyOWS log and check if there's any error message in
it ?
- Could you use Firebug with OpenLayers to check the TinyOWS output stream ?
HTH,
Olivier
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120202/dc523795/attachment.html
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
End of mapserver-users Digest, Vol 49, Issue 4
