[mapserver-users] MapCache with GTiff Cache
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 26 01:44:57 PDT 2013
Arthur,
The TIFF cache backend is efficient and performant, however it is not easy
or flexible to setup. Basically you *must* ensure that the provided TIFFs
are exactly aligned to your mapcache grid, and this for every zoom level
you want to serve.
I would suggest you create a TIFF cache from scratch on the "test"
datasource , by enabling tiff write support in mapcache. Once you have
browsed/seeded a few layers, the structure of what mapcache is awaiting
given the <template> you provide will hopefully be clearer.
Remove the <base> from your tiff source, use only the <template> and give
it a full path, e.g.
<template>/path/to/tiff-cache/{tileset}/{grid}/L{z}/R{inv_y}/C{x}.tif</template>
Please submit a patch to the docs if you think they should be enhanced.
thomas
On 25 April 2013 17:41, Arthur Wesley <arwesley at web.de> wrote:
> Hello Mapserver-Community, Hello List,
> first of all i want to thanks for the great work you guys are doing. The
> mapserver-project with all his facets does really deliver a great range of
> useful tools and services for different questions.
> Right now i am looking for a WMS and WMTS solution for publishing big
> amounts of high resolution tiffs. Because of concerns about our disk
> storage i would like to use only a single raster datastore for both
> services, i.e. WMS and WMTS.
> The realization of a WMS Service in front of a tiff datastore is no
> problem with mapserver / mapfile. For the realization of a WMTS solution i
> set up the extension mapcache. I also got it running as disk cache
> solution. But i want to try if it is possible to set up it in front of the
> tiff datastore. As it says in the documentation (
> http://mapserver.org/mapcache/caches.html#mapcache-cache-tiff) it is
> possible to use a gtiff cache, but right now i didn't get it running (see
> my mapcache.xml in annex). Also i don't have real knowledge about the
> structure of the tiff store for mapcache. As far as i know gdal gives me
> with the tools gdal2tiles and gdal_retile/gdaltindex two tools for
> computing a tile structure. Could such a structure reused or do i have to
> use another structure? Anyway i am quit new to tiling storys, so maybe i
> just don't get it.
> It would be nice if somebody could show me mapcache.xml example for a tiff
> cache and maybe could also descripe the needed structure of the tiff store.
> I really appreciate your help. Thanks in advance.
> Kind regards,
> JM
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130426/fa528ff9/attachment.html>
