[mapserver-users] mapcache - serving air photos to ArcMap
Travis Kirstine traviskirstine at gmail.com
Mon Feb 24 06:23:20 PST 2014
Do you have the wms service enabled in the mapcache config file
http://mapserver.org/mapcache/config.html#services
BTW ArcMap 10.1 can access a mapcache WMTS as well (faster and less load)
On 24 February 2014 08:43, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> I apologize.  I meant to say that I can currently use Mapserver to serve
> WMS to any client.  What I meant to say is that in addition to MapServer, I
> am trying to use Mapcache as well.  I am not sure if the online resource is
> set correct.
> http://geomoose.lyonco.org:8080/mapcache/mapcache?service=wms&request=getcapabilities
> Sincerely,
> Mark Volz, GISP
> > Message: 5
> > Date: Fri, 21 Feb 2014 20:27:05 -0700
> > From: Richard Greenwood <richard.greenwood at gmail.com>
> > To: Mark Volz <MarkVolz at co.lyon.mn.us>
> > Cc: "mapserver-users at lists.osgeo.org"
> >       <mapserver-users at lists.osgeo.org>
> > Subject: Re: [mapserver-users] mapcache - serving air photos to ArcMap
> >       and     AutoCAD
> > Message-ID:
> >       <CAHBySPYMy6vvuS9stB=wrbzvYrkk7KX4vU=T80kN2RpgFnGzzA at m
> > ail.gmail.com>
> > Content-Type: text/plain; charset="iso-8859-1"
> > You may have this already, but I know that to get ArcMap to read
> MapServer
> > WMS you must have a title and srs definition in the map file's layer
> metadata.
> > For example:
> >   METADATA   # stuff for WMS to make ArcMap happy
> >     "wms_title"  "Layer Name" # REQUIRED
> >     "wms_srs"   "EPSG:3739"  # REQUIRED
> >   END
> > Rich
> > On Fri, Feb 21, 2014 at 1:15 PM, Mark Volz <MarkVolz at co.lyon.mn.us>
> > wrote:
> > > Hello,
> > > In the past I have used MapServer to serve wms to several different
> > > applications.  It worked fine.  Now I am trying to use MapCache to
> > > serve to WMS clients.  It is not working for all of my clients.
> > > Openlayers and QGIS Work.
> > > ArcMap
> > > - Error:  WMS Server exceptions: Service Error.  Description: received
> > > unsuitable wms request: no <grid> with suitable srs found for layer
> > > USGS2006.
> > > AutoCAD Civil 3D
> > > - Failed to get bands data.  The HTTP request could not be understood
> > > by the server due to malformed syntax.
> > > If anyone has any thoughts on how I can fix this issue let me know.
> > > Thanks
> > > Sincerely,
> > > Mark Volz
> > > _______________________________________________
> > > mapserver-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Richard Greenwood
> > www.greenwoodmap.com
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <http://lists.osgeo.org/pipermail/mapserver-
> > users/attachments/20140221/b11670af/attachment-0001.html>
> > End of mapserver-users Digest, Vol 73, Issue 37
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140224/2fbf4602/attachment.html>
