[mapserver-users] MspServer Cluster Problem.
LewInMadrid
LCLARK at GENASYS.COM
Fri Jan 10 01:15:13 PST 2014
Thanks. If I remove CLASSITEM and EXPRESSION it works as expected.
However, I'm now trying to use the GROUP/FILTER functionality to only
cluster the data based on the status attribute value.
If I do the following I see the symbols but the FeatureCount is often blank.
CLUSTER
MAXDISTANCE 30 # in pixels
REGION "rectangle" # can be rectangle or ellipse
GROUP ('[status]' = 'E' )
END
<http://osgeo-org.1560.x6.nabble.com/file/n5097293/map_number_blank.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MspServer-Cluster-Problem-tp5097138p5097293.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
