[mapserver-users] Rendering of adjacent dashed lines
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Jun 17 07:20:23 PDT 2016
The only method that really works is to remove adjacent lines. Your trick seems to be the same as this https://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Using-a-dashed-line-symbol-with-adjacent-polygons-masking.html
but they used a wider white line. However, it feels usable only if the background is also white and there are no lines very close to each other.
-Jukka Rahkonen-
Ziegler Stefan wrote:
> Hi
> I'm trying to render some lines with a pattern. This works and looks great as long as the lines are not adjacent. When the lines share a common border the dashed lines may look ugly since one dashed line is rendered on top of the other rendered dashed line. I tried to add a white solid line under the dashed line:
CLASS
STYLE
COLOR 255 255 255
WIDTH 2
LINECAP BUTT
END
STYLE
COLOR 0 0 0
WIDTH 2
LINECAP BUTT
PATTERN 20 4 2 4 2 4 END
END
END
But the behaviour is still the same. Is there a trick/workaround for this? I'm using MapServer 7.0.1.
Best regards
Stefan Ziegler
Freundliche Grüsse
Stefan Ziegler
Kantonsgeometer / Leiter Amt für Geoinformation
Rötistrasse 4
4500 Solothurn
Telefon +41 32 627 75 96
Telefax +41 32 627 75 98
stefan.ziegler at bd.so.ch
http://www.so.ch
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
