[mapserver-users] MAP_RESOLUTION parameter
Marco Afonso mafonso333 at gmail.com
Wed Nov 16 03:41:34 PST 2016
Oh yes you are right it is not on the standards, so it can only be a vendor
param.
Anyway the purpose of this thread is to ask for documentation about
MAP_RESOLUTION param.
I will create an issue on github then.
Thanks!
Em 16/11/2016 11:02, "Rahkonen Jukka (MML)" <
jukka.rahkonen at maanmittauslaitos.fi> escreveu:
> Hi,
> WMS vendor parameter is an extra parameter that does not belong to those
> which are defined in the standard, but which makes some difference to WMS
> output if it is used with a server that knows what to do with it. Other
> servers must just skip it.  Therefore I think that MAP_RESOLUTION is
> exactly a vendor parameter in the same way than these great vendor
> parameters of Geoserver http://docs.geoserver.org/
> stable/en/user/services/wms/vendor.html.
> -Jukka Rahkonen-
> *Lähettäjä:* Marco Afonso [mailto:mafonso333 at gmail.com]
> *Lähetetty:* 16. marraskuuta 2016 12:50
> *Vastaanottaja:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> *Kopio:* mapserver <mapserver-users at lists.osgeo.org>
> *Aihe:* Re: [mapserver-users] MAP_RESOLUTION parameter
> Thank you Jukka.
> I dont think it should be a vendor param as one can build a WMS URL with
> the desired resolution.
> Im even thinking displaying a combo box to the user choose from the
> resolution predefined options.
> This is great param :)
> Em 16/11/2016 10:18, "Rahkonen Jukka (MML)" <jukka.rahkonen@
> Hi,
> There was some discussion 5 years ago https://lists.osgeo.org/
> pipermail/mapserver-users/2011-June/069136.html but obviously I did not
> made the documentation ticket.
> Because MAP_RESOLUTION can be used without having it in the mapfile I feel
> that it should be documented in http://mapserver.org/ogc/wms_server.html
> as a vendor parameter. For Mapserver CGI the place could be
> http://mapserver.org/cgi/controls.html. MAP.RESOLUTION and
> MAP.DEFRESOLUTION is the syntax to use as cgi controls.
> The default value is 72 and that is documented in http://mapserver.org/
> development/rfc/ms-rfc-55.html.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [mailto:mapserver-users-
> bounces at lists.osgeo.org] *Puolesta *Marco Afonso
> *Lähetetty:* 16. marraskuuta 2016 11:47
> *Vastaanottaja:* mapserver <mapserver-users at lists.osgeo.org>
> *Aihe:* [mapserver-users] MAP_RESOLUTION parameter
> Hello,
> By using OpenLayers 3 and WMS I found a really usefull parameter:
> MAP_RESOLUTION.
> It's very important to request images with higher resolution for printing.
> I did some search about it's documentation but I can't find any.
> I found references to MAP.RESOLUTION and MAP.DEFRESOLUTION but not about
> MAP_RESOLUTION.
> Please where I can find documentation about this parameter.
> What is the default value assumed if MAP_RESOLUTION is missing on the WMS
> request?
> Thank you!
> Regards,
> Marco Afonso
> http://goo.gl/ZDtQjm
> [image: Lähettäjä poisti kuvan.]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161116/e75875b0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161116/e75875b0/attachment-0001.jpg>
