[mapserver-users] Reprojection error for CONNECTIONTYPE WMS
Simon.Schneegans at dlr.de
Fri Jun 2 02:11:56 PDT 2017
Hi there!
I tested some more and it seems that this is not only a problem for WMS layers, but for Raster layers as well. Here is an example GeoTiff:
https://github.com/mapserver/mapserver/files/1047153/test.zip
I can warp this to HEALPix using GDAL on the command line:
gdalwarp -t_srs '+proj=healpix +a=1 +b=1 +wktext' -te -0.5 0.6 0.5 1 test.tiff healpix.tiff
The result looks as supposed (see example in the original issue: https://github.com/mapserver/mapserver/issues/5437).
However, if I let mapserver do the reprojection, the result is distorted (e.g. Libya is missing on the map). This is my layer (except for some metadata):
LAYER
name "test"
status ON
type RASTER
data "test.tiff"
PROJECTION
AUTO
END
END
This is in my epsg file:
<900916> +proj=healpix +a=1 +b=1 <>
This is the relevant part of the WMS request:
...&LAYERS=test&WIDTH=600&HEIGHT=300&SRS=EPSG:900916&BBOX=-0.5,0.6,0.5,1
The example test.tiff I linked above covers exactly the area I am requesting to be reprojected to HEALPix. As soon as this input tiff is larger, the reprojection works as supposed. I guess that this is the reason why I observed the issue with CONNECTIONTYPE WMS first: Here the input data is usually exactly as large as required by the reprojection!
Where do I have to go bug hunting? Is it a configuration issue? Is it a reprojection issue specific to HEALPix?
Thank you for your support!
Simon
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Simon.Schneegans at dlr.de
Gesendet: Dienstag, 30. Mai 2017 13:17
An: mapserver-users at lists.osgeo.org
Betreff: [mapserver-users] Reprojection error for CONNECTIONTYPE WMS
Hi there!
I am happily using mapserver to reproject raster data to the HEALPix projection from proj.4<http://proj4.org/projections/healpix.html>. This works pretty well for local raster sources, however I get severe reprojection problems when using an external WMS as source for my layer.
I reported this issue on Github (https://github.com/mapserver/mapserver/issues/5437) but was told to ask here for assistance. Instead of copy-pasting the text from the Github issue to this mail, I kindly ask you to refer to this Github issue for further information; there I also included several images illustrating the problem.
I am looking forward to get any feedback or input that helps me solving this issue!
Thank you very much!
Simon
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Simon Schneegans, M. Sc.
Telephone +49 531 295-2333 | Telefax +49 531 295-12100 | simon.schneegans at dlr.de<mailto:simon.schneegans at dlr.de>
DLR.de<http://www.dlr.de/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170602/7a8ee631/attachment.html>
