[mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Even Rouault
even.rouault at spatialys.com
Fri Jun 30 06:50:09 PDT 2017
On vendredi 30 juin 2017 07:00:40 CEST Michael Smith wrote:
> What os? I know the mapserver docker packages
> (https://hub.docker.com/r/mapserver/mapserver/) have it but most of the
> windows versions, MS4W, GisInternals, don’t. Don’t know about OSGeo4W.
I'm wondering if we shouldn't revisit the decision to have USE_POINT_Z_M disabled by
default. This is often annoying.
Apparently, adding USE_POINT_Z_M defaulting to OFF was driven by performance reasons
per https://github.com/mapserver/mapserver/issues/1244 . But this was 12 years ago.
Perhaps with recent hardware the performance difference isn't that big. The ticket
unfortunately doesn't contain a test case to bench (likely lots of lines/polygons, or large
lines/polygons to render). If the perf difference is still there, a more involved change would
be indeed to move the z and m components into separate arrays.
> Michael Smith
> Remote Sensing/GIS Center
> US Army Corps of Engineers
> > On Jun 30, 2017, at 6:12 AM, Daniel Hardes <hardes at 3dis.de> wrote:
> > Ok. Is there a prebuild version with USE_POINT_Z_M somewhere?
> >> Michael Smith <michael.smith.erdc at gmail.com> hat am 30. Juni 2017 um
> >> 12:02 geschrieben:
> >> Daniel,
> >> There is a section in the OGC WFS Server docs that explains this. Look at
> >> http://mapserver.org/ogc/wfs_server.html#reference-section, specifically
> >> the Layer section. You have to have mapserver compiled with
> >> USE_POINT_Z_M support and you have to set the geometry type to a 2.5D
> >> type, eg something like "ows_geomtype" "Polygon25D"
> >> Michael Smith
> >>> On Jun 30, 2017, at 5:49 AM, Daniel Hardes <hardes at 3dis.de> wrote:
> >>> Hello,
> >>> i have a PostGIS database with point, line and polygon geometries and
> >>> all have a Z-coordinate.
> >>> First problem: Is it possible to create a layer in the mapfile without a
> >>> fixes type? i think a layer has to have a Type property but there ist
> >>> no general geometry type.
> >>> Second problem: All coordinates have only X and Y values.... but no Z
> >>> value... they have the value in the database. Is it possible zu get the
> >>> Z-coordinate from the WFS?
> >>> Greetings Daniel
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> mapserver-users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170630/5b11971e/attachment-0001.html>
