[mapserver-users] 3D / 2.5D / Coordinates with Z and GEOMETRY Type in WFS
Daniel Morissette
dmorissette at mapgears.com
Fri Jun 30 06:59:30 PDT 2017
On 2017-06-30 9:50 AM, Even Rouault wrote:
> I'm wondering if we shouldn't revisit the decision to have USE_POINT_Z_M
> disabled by default. This is often annoying.
> Apparently, adding USE_POINT_Z_M defaulting to OFF was driven by
> performance reasons per
> https://github.com/mapserver/mapserver/issues/1244 . But this was 12
> years ago. Perhaps with recent hardware the performance difference isn't
> that big. The ticket unfortunately doesn't contain a test case to bench
> (likely lots of lines/polygons, or large lines/polygons to render). If
> the perf difference is still there, a more involved change would be
> indeed to move the z and m components into separate arrays.
#1244 refers to #1224 which is using the gmap demo mapfile... which is a
relatively small dataset, so it should be easy to verify if the issue is
still relevant on more recent hardware using gmap or probably any other
dataset.
https://github.com/mapserver/mapserver-import/issues/1224
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
