[OpenLayers-Dev] draw non-circle nodetype point features ?
Attila Csipa plists at prometheus.org.yu
Wed Feb 27 09:30:39 EST 2008
Is there a preferred/suggested way of drawing point features OTHER than a
circle ? In #1284 for example a square highlight is drawn (which is
technically a point feature). A patch in
http://trac.openlayers.org/ticket/1398 allows defining a pointStyle property
which defines whether the node drawn should be a circle, rectangle, etc. Full
SVG object insertion/specification seemed a bit of an overkill, but if
someone has a better idea, I'm all ears.
More information about the Dev mailing list
