[OpenLayers-Users] [OpenLayers-Dev] Zoom Problems Switching Baselayers -- HELP!
Arnd Wippermann arnd.wippermann at web.de
Tue Oct 9 14:53:13 EDT 2007
I have build my singlefile from the source of the today trunk (Revision
4878).
Switching between baselayers don't change the zoomlevel any more. But now I
get trouble, when I resize the window and then switch the baselayer.
Something get lost. The new baselayer only displayed in the left upper
corner or at the wrong zoomlevel. Also pan will not work correctly anymore.
Resizing the window will correct the odd behaviour.
This is also with Version 2.5 RC1, Revision 4347, but I have it not noticed
before.
Tested with FF and IE6.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: euzuro at gmail.com [mailto:euzuro at gmail.com] Im Auftrag von Erik Uzureau
Gesendet: Dienstag, 9. Oktober 2007 06:21
An: Arnd Wippermann
Betreff: Re: [OpenLayers-Dev] Zoom Problems Switching Baselayers -- HELP!
Hmm. I can't see how this would ever happen here, since the resolution
arrays are all the same for all layers.
At any rate, running the html file on trunk I am unable to reproduce it.
I think for now we're going to call it "fixed" unless it resurfaces again.
Thank you for your help with this, Arnd
Erik
On 10/4/07, Arnd Wippermann <arnd.wippermann at web.de> wrote:
> Hello,
> Without using the zoom control I can only with swapping the baselayers
> go down the zoom levels. It's not with all zoom levels, but I think,
> when you take different zoom levels and then swap some times the
> baselayers you will activate the zooming.
> After resizing the window, other zoom levels show this odd behaviour.
> Arnd Wippermann
> Uzureau
> Gesendet: Donnerstag, 4. Oktober 2007 20:42
> An: Arnd Wippermann
> No, we can do the testing, we just need an explanation as to what is
> broken with this example. Can you say how the zooming is broken?
> For example, "zoom in four times, pan right five times, then switch
> baselayers. You will notice that xxx has happened"
> Erik
> > Hello Erik,
> > I have thought, you need only an example which this behavior shows.
> > I haven't tested with the patches.
> > Arnd Wippermann
> > Uzureau
> > Gesendet: Donnerstag, 4. Oktober 2007 18:23
> > An: Arnd Wippermann
> > Cc: dev at openlayers.org
HELP!
> > Hi Arnd,
> > Thanks for sending this test code... can you explain what we should
> > test for, though?
> > ie how do we know if our patch has fixed the problem for you?
> > Erik
> > On 10/3/07, Arnd Wippermann <arnd.wippermann at web.de> wrote:
> > > And the file
> > > Arnd Wippermann
> > > _______________________________________________
> > > Dev mailing list
> > > Dev at openlayers.org
> > > http://openlayers.org/mailman/listinfo/dev
