[OpenLayers-Users] wms scalehint and minScale maxScale
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 10 10:27:03 EDT 2007
still doesn't seem to work properly...
there are very few occurances of minScale in the whol openlayers code base, hmm?
z
On 10/10/07, Chris Tweedie <chrislist at narx.net> wrote:
> Try maxscale : 1.5mill and minscale : 3500
> Havent tested it though, but if GA stick to the ESRI recommendations they use the 3846.15 multiplier. From this number you can kinda of guesstimate the rest.
> Chris
> On Wed, 10 Oct 2007 04:56:09 -0700 (PDT), zspitzer <zac.spitzer at gmail.com> wrote:
> > using this wms server
> > http://mapconnect.ga.gov.au:80/wmsconnector/com.esri.wms.Esrimap/GDA94_MapConnect_SDE_250kmap_WMS?
> > I am trying to set the min and max scale for the layer, the WMS
> > getCapabilites has for example
> > <ScaleHint min="0.9353050112837813" max="374.12200451351254"/>
> > If i set this via maxScale and minScale in the Layer, the layer never
> > shows
> > The SRS is EPSG:4326
> > i am using the http://labs.metacarta.com/wms/vmap0 base layer
> > View this message in context:
> > http://www.nabble.com/wms-scalehint-and-minScale-maxScale-tf4600035.html#a13133444
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Chris Tweedie
Zac Spitzer
http://zacster.blogspot.com/
+61 405 847 168 (aussie moible)
Zac Spitzer
