[OpenLayers-Users] OpenLayers in Rails
Michael Quentel mquentel at rim.com
Wed Oct 10 10:54:01 EDT 2007
Try modifying the image path in Utils.js to what the Rails application
would use for the img and theme directories.
Regards,
Mike Quentel
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Christopher Schmidt
Sent: Wednesday, 10 October 2007 02:13
To: staff-gmail
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] OpenLayers in Rails
On Tue, Oct 09, 2007 at 11:16:46PM -0600, staff-gmail wrote:
> The control icons are not showing up in Rails - I have OpenLayers.js
> from the build directory in the Rails javascripts folder  and put the
> /img and /theme also within the javascripts folder but they are not
> being accessed correctly.  The control buttons seem to work okay - but
> the images don't show.  Anyone work around this ?
If you look at the image location in firebug (Hit "Inspect"), what is
the URL it is tryign to load?
Regards,
Christopher Schmidt
MetaCarta
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
