[OpenLayers-Users] Need for pan mode when digitizing a feature
near map edge
mcarsel
carsella11 at msn.com
Fri Sep 14 19:06:12 EDT 2007
Thanks for the quick response. Google MyMaps allows a drag pan from anywhere
while digitizing. I was mistaken, you don't have to be near the map edge.
They also have a right click 'Center Map Here' function.
It might make the coding simpler to allow a drag pan. I notice also that
OpenLayers already supports zoom in/out while digitizing but it's pretty
unwieldy without a pan.
Christopher Schmidt-4 wrote:
> On Fri, Sep 14, 2007 at 01:44:03PM -0700, mcarsel wrote:
>> We need a way to pan the map while in the midst of digitizing a feature
>> near
>> the map edge, say within 30 pixels. The mouse pointer could change to
>> the
>> pan icon when the cursor is near the edge to give the user an opportunity
>> to
>> pan. After the user pans the map, the user could continue with
>> digitizing
>> the current feature. See Google MyMaps for a good example.
>> Is this doable in OpenLayers?
> The code doesn't exist, but has been developed in the past, and may
> still exist in the old vector sandbox:
> http://svn.openlayers.org/sandbox/vector/
> But it would require a big chunk of work to get it in.
> I think that this is on target from camptocamp under 2.6 -- maybe
> someone from their side of the pond can comment on the
> possibilities/likelihook of that?
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Need-for-pan-mode-when-digitizing-a-feature-near-map-edge-tf4445226.html#a12685237
