[OpenLayers-Users] Need for pan mode when digitizing a feature near map edge
Arnd Wippermann arnd.wippermann at web.de
Sat Sep 15 14:49:24 EDT 2007
It's possible to use the pan buttons of the panzoom control while in
digitizing mode. See the example
http://openlayers.org/dev/examples/spherical-mercator.html Tim Schaub had
named yesterday.
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von mcarsel
Gesendet: Samstag, 15. September 2007 01:06
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Need for pan mode when digitizing a feature
near map edge
Thanks for the quick response.  Google MyMaps allows a drag pan from
anywhere while digitizing.  I was mistaken, you don't have to be near the
map edge.
They also have a right click 'Center Map Here' function.
It might make the coding simpler to allow a drag pan.  I notice also that
OpenLayers already supports zoom in/out while digitizing but it's pretty
unwieldy without a pan.
Christopher Schmidt-4 wrote:
> On Fri, Sep 14, 2007 at 01:44:03PM -0700, mcarsel wrote:
>> We need a way to pan the map while in the midst of digitizing a
>> feature near the map edge, say within 30 pixels.  The mouse pointer
>> could change to the pan icon when the cursor is near the edge to give
>> the user an opportunity to pan.  After the user pans the map, the
>> user could continue with digitizing the current feature. See Google
>> MyMaps for a good example.
>> Is this doable in OpenLayers?
> The code doesn't exist, but has been developed in the past, and may
> still exist in the old vector sandbox:
> http://svn.openlayers.org/sandbox/vector/
> But it would require a big chunk of work to get it in.
> I think that this is on target from camptocamp under 2.6 -- maybe
> someone from their side of the pond can comment on the
> possibilities/likelihook of that?
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context:
http://www.nabble.com/Need-for-pan-mode-when-digitizing-a-feature-near-map-e
dge-tf4445226.html#a12685237
Users mailing list
