[OpenLayers-Users] Need for pan mode when digitizing a feature
near map edge
mcarsel
carsella11 at msn.com
Sat Sep 15 17:16:50 EDT 2007
Thanks Arnd, that helps a lot. I see why drag pan now is a low priority.
Arnd Wippermann wrote:
> It's possible to use the pan buttons of the panzoom control while in
> digitizing mode. See the example
> http://openlayers.org/dev/examples/spherical-mercator.html Tim Schaub had
> named yesterday.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/ginfo/
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von mcarsel
> Gesendet: Samstag, 15. September 2007 01:06
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Need for pan mode when digitizing a
> feature
> near map edge
> Thanks for the quick response. Google MyMaps allows a drag pan from
> anywhere while digitizing. I was mistaken, you don't have to be near the
> map edge.
> They also have a right click 'Center Map Here' function.
> It might make the coding simpler to allow a drag pan. I notice also that
> OpenLayers already supports zoom in/out while digitizing but it's pretty
> unwieldy without a pan.
> Christopher Schmidt-4 wrote:
>> On Fri, Sep 14, 2007 at 01:44:03PM -0700, mcarsel wrote:
>>> We need a way to pan the map while in the midst of digitizing a
>>> feature near the map edge, say within 30 pixels. The mouse pointer
>>> could change to the pan icon when the cursor is near the edge to give
>>> the user an opportunity to pan. After the user pans the map, the
>>> user could continue with digitizing the current feature. See Google
>>> MyMaps for a good example.
>>> Is this doable in OpenLayers?
>> The code doesn't exist, but has been developed in the past, and may
>> still exist in the old vector sandbox:
>> http://svn.openlayers.org/sandbox/vector/
>> But it would require a big chunk of work to get it in.
>> I think that this is on target from camptocamp under 2.6 -- maybe
>> someone from their side of the pond can comment on the
>> possibilities/likelihook of that?
>> Regards,
>> Christopher Schmidt
>> MetaCarta
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> http://www.nabble.com/Need-for-pan-mode-when-digitizing-a-feature-near-map-e
> dge-tf4445226.html#a12685237
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Need-for-pan-mode-when-digitizing-a-feature-near-map-edge-tf4445226.html#a12693949
