[OpenLayers-Users] Busy Cursor
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Wed Apr 9 07:48:54 EDT 2008
Yes, it's not in the standard library, I am hoping it can be an addin soon.
See also the Wiki:
http://trac.openlayers.org/wiki/Addins/LoadingPanel
You can add the following in a <script> tag after the OpenLayers.js <script>
tag:
http://dev.openlayers.org/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
Or build your own OpenLayers.js. See also the Wiki page for details. You
also need to use a bit of css to get the background-image. It's described in
the Wiki page.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Carlos Pinto <cmspinto at gmail.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: Linda Rawson <linda.rawson at gmail.com>, OpenLayers Users
<users at openlayers.org>
Onderwerp: Re: [OpenLayers-Users] Busy Cursor
Datum: 09/04/08 09:41
> Hi all, I am using the library &quot;&lt;script&nbsp;
src=&quot;http://www.openlayers.org/dev/lib/OpenLayers.js&quot;&gt;&lt;/script&gt;&quot;but
I have seen this post and I thought that is really a good idea to put a
loading panel but when I had the line:
> map.addControl( new OpenLayers.Control.LoadingPanel({minSize: new
OpenLayers.Size(600, 600)}) );the map don&#39;t appear!!!!!!Is it because of
the openlayers version I am using?ThanksCarlos
> On Wed, Apr 9, 2008 at 9:32 AM, Bart van den Eijnden (OSGIS)
&lt;bartvde at osgis.nl&gt; wrote:
> Hi Linda,
> you could have a look at the LoadingPanel Control. Something similar could
> be done to change the map cursor.
> See:
> http://trac.openlayers.org/ticket/102
> and:
http://trac.openlayers.org/browser/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
> In maximizeControl you could set the busy mouse cursor on the map div, and
> in minimizeControl change the cursor back.
> example:
http://dev.openlayers.org/sandbox/bartvde/loadingpanel/examples/loadingpanel.html
> Best regards,
> Bart
> http://www.osgis.nl
> Van: Linda Rawson &lt;linda.rawson at gmail.com&gt;
> Naar: OpenLayers Users &lt;users at openlayers.org&gt;
> Onderwerp: [OpenLayers-Users] Busy Cursor
> Datum: 09/04/08 01:05
> &gt; I have two layers that when I switch between them the performance is
> &gt; so bad that there is a noticeable delay. &nbsp;How would I implement
an
> &gt; hourglass cursor to indicate to the user that the application is
> &gt; working and then put the cursor back to normal when the layer is
> &gt; loaded.
> &gt;
> &gt; --
> &gt; Linda Rawson
> &gt; _______________________________________________
> &gt; Users mailing list
> &gt; Users at openlayers.org
> &gt; http://openlayers.org/mailman/listinfo/users
> &gt;
> &gt;
> Users mailing list
