[OpenLayers-Users] panTo() outside of the extents
Eric Lemoine eric.c2c at gmail.com
Fri Jun 6 01:58:20 EDT 2008
On Thu, Jun 5, 2008 at 7:38 PM, aschwartz <aschwartz at solidworks.com> wrote:
> Hello all,
Hello
> In the map.panTo Example, it says "If the new random center is in the
> current extent, the map will pan smoothly. "
> Is there a way to change it so that panTo will pan smoothly no matter what?
No. You'd need to look at the panTo code and implement your own panTo method.
<http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Map.js#L1368>
> Also is the extent referring to the bounds of your current view of the map,
> or is it referring to the actual extent set in code with Openlayers.bounds?
The former.
Eric
