[OpenLayers-Users] Externally toggle a marker's popup
Alan Boudreault aboudreault at mapgears.com
Fri Jun 13 16:15:20 EDT 2008
Hi aschwartz,
First of all, you'll need to access this marker.  A simple way is to
keep a trace of it. How do you add it to your map ? If you create/add
this marker in a function at the load of your page, you can just create
a global variable and assign to it the marker. In this case, you'll be
able to create a JS function to toggle this marker easily by setting
something like: href="javascript:toggleMyMarker();". There is a lot of
way to do what you want.
Regards,
Alan
aschwartz wrote:
> So I've been hunting around trying to figure this out, and I've been looking
> in Firebug for some information on that popup. The first thing i noticed is
> that a popup has an optional field for 'id'... this could come in handy.
> I also saw it was given a numbered id (see screenshot -
> http://gtproductions.net/uploads/firebug.jpg )
> How do I call this thing, in OO JS style?
> Openlayers.Feature_95_popup.toggle(); ??
> make an array of markers and do
> markerArray[i].Openlayers.Feature_95_popup.toggle(); ??
> I have no idea. Any help would be appreciated.
> -Alex
Alan Boudreault
Mapgears
http://www.mapgears.com
