[OpenLayers-Users] Map is shifted to the right, click gets wrong position
Geoff Hopson geoff.hopson at gmail.com
Sun Jun 15 12:05:26 EDT 2008
Is the div centered? That caught me out on IE...take off the center,
see if that helps...
Geoff
2008/6/15 Zer <hcan at hotmail.com>:
> Dear List,
> I have a problem with my Vector Layer. When a user clicks in the map, a new
> GML request is sent to Geoserver requesting an object intersecting the
> clicked point. The first vector is drawn correctly on the map and the map is
> centred correctly. When the user continues to click in the map, the position
> he clicks on is shifted to the right. What happens is that a request that is
> sent to the server contains the wrong coordinates.  When that object is
> drawn on the map, the map gets repositioned and shifted to the right.
> This only happens in IE7, not in Firefox. The map is inside a Dojo Layout
> container div, and the the right of the map there is another Dojo container
> div showing text information. It seems like the map get shifted to the right
> the same amount of pixels as the right hand side div is. if I zoom out and
> then back again, the map gets repositioned and the vector object shows up in
> the centre of the map.
> I have tried to call map.updateSize(), but the problem didn't get fixed. Is
> there anyone out there that has a clue of what is causing this problem? And
> how to solve it?
> Thanks,
> -z
> View this message in context: http://www.nabble.com/Map-is-shifted-to-the-right%2C-click-gets-wrong-position-tp17851229p17851229.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Mario Kart Wii: 2320 6406 5974
