[OpenLayers-Users] Google-like tiles in an example
Erik Uzureau euzuro at gmail.com
Wed Mar 5 10:43:56 EST 2008
Chis, do you think it would be helpful if we added this or a similar
example to the /examples directory?
...or is there maybe an example already there that does this?
erik
On 3/4/08, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Mar 04, 2008 at 06:16:44PM -0800, Coryat wrote:
> > Chris,
> > Actually, the hardest part was figuring out what version to use, I was a bit
> > confused by the different builds, the example I was trying to follow had a
> > Projection.js but the stable version didn't. I can only assume that this is
> > part of 2.6, is that the case?
> Yep. Projection code is in what is currently 'trunk', which will become
> 2.6 reasonably soon. http://openlayers.org/dev/lib/OpenLayers.js and
> /dev/examples/* are running a 'current' checkout, always.
> http://dev.openlayers.org/nightly/OpenLayers.js is running a trunk build
> from 1AM eastern, always. http://openlayers.org/api/OpenLayers.js is
> running the most recent stable build (and getting to a stable build is a
> long process for us).
> > I'm going to be expanding on this simple example, so if there was a better
> > way of converting WGS84 lat/long coordinates into map positions in
> > OpenLayers, now would be the time to know.
> I think everything you've done is the same way I would go about doing
> it, so at the very least you're not too far off the mark :)
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
