[OpenLayers-Users] bug when having layers with minScale/maxScale?
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Tue Mar 11 06:32:03 EDT 2008
Hi list,
using trunk (but I believe this has been in the library for a long time
already) we have encountered the following problem:
-define a layer with minScale and maxScale (layer is visible between 1:500
and 1:50000 for instance)
-zoom in to scale 1:45000 so the layer is visible
-call setVisibility(false) on the layer
-zoom out to 1:200000 for instance
-call setVisibility(true) on the layer
The layer will show the old tile, see e.g.:
http://www.osgis.nl/download/MR01.JPG
I could solve it by removing the inRange check in Layer.js:
if (extent && this.inRange && this.visibility) {
    this.moveTo(extent, true, false);
    redrawn = true;
to:
if (extent && this.visibility) {
    redrawn = true;
but there should be a better way for sure. TIA.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
