[OpenLayers-Users] Can't get VE map to work
chaak
haak at agintegrated.com
Thu Oct 9 11:57:04 EDT 2008
Hi Lennox,
I don't know if you've found your error yet, but maybe I can help a little.
I fought with a weird error with the panning as well. I only had a problem
when using Virtual Earth; probably similar to what you were having, but I
didn't see it on the site that you posted. I tracked my error down to being
a conflict with the Virtual Earth variables that they use in their JS file.
MicroSoft obstruficates their code, so everything runs off of variables like
a, b, c, etc... After a few days of searching through my code, I found I
had one "g" variable set globally, which conflicted with the VE g function.
Look in your error console and see if there is an error based on a letter.
If so, chances are that you're experiencing what I did.
Chris
Lennox Antoine wrote:
> I've noticed a resize issue. Don't know if it's new or not though. Take a
> look at this map :
> http://vizuresoft.com/mapstudio/clients/D5D90F37AACB3ACEB42192770369E577/map10/fullscreen.html.
> Don't mind the cartesian overlay over the mercator map.
> It starts out with Google Maps. Switch to Virtual Earth. Notice that if
> you
> try to pan now, it doesn't pan correctly. It only seems to occur with the
> Virtual Earth map. Switch to any of the other basemaps, and it doesn't
> behave this way.
> Lennox
View this message in context: http://n2.nabble.com/Can%27t-get-VE-map-to-work-tp1088773p1312656.html
