[OpenLayers-Users] Can't get VE map to work
Lennox Antoine lxnyce at gmail.com
Fri Oct 3 13:26:28 EDT 2008
I've noticed a resize issue. Don't know if it's new or not though. Take a
look at this map :
http://vizuresoft.com/mapstudio/clients/D5D90F37AACB3ACEB42192770369E577/map10/fullscreen.html.
Don't mind the cartesian overlay over the mercator map.
It starts out with Google Maps. Switch to Virtual Earth. Notice that if you
try to pan now, it doesn't pan correctly. It only seems to occur with the
Virtual Earth map. Switch to any of the other basemaps, and it doesn't
behave this way.
Lennox
On Fri, Oct 3, 2008 at 11:52 AM, chaak <haak at agintegrated.com> wrote:
> As a note to all who read this, I've tested the 2.7-rc2 library and
> everything seems functional except for the fact that vector layers on top
> of
> the VE layer will be panned instead of the base VE layer.  Just some info
> for the common cause because I was caught off guard by Microsoft shutting
> off v3.
> http://n2.nabble.com/Can%27t-get-VE-map-to-work-tp1088773p1142295.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081003/2f28afcf/attachment.html
