[OpenLayers-Users] DrawFeature control not working properly
Eric Lemoine
eric.c2c at gmail.com
Tue Jan 20 02:00:54 EST 2009
Hi Jatin
Does the test also fail with trunk? (I can't check right now)
Eric
2009/1/20, Jatin Ambasana <jatin.a at iworktech.com>:
> Hello Eric,
>>What OpenLayers version do you use?
> I use OpenLayers-2.7 latest version.
>>Changeset 8616 (<http://trac.openlayers.org/changeset/8616>) should
>>fix it, give trunk a try.
> Yes Thank you very much Eric..... it has solved my problem....=)
> I am able to draw the polygon on single click and also add it in the
> layer.....
> Here is the code added in zip file that I have done to just draw a circle of
> specific size on just one click and also it provides a functionality that
> user can draw only one circle at a time..... it could be useful for someone
> else also.....
> But Eric,
> There is one problem that I think I need to inform you about...
> I updated both the files
> from http://trac.openlayers.org/changeset/8616
> i.e.
> 1) trunk/openlayers/lib/OpenLayers/Handler/RegularPolygon.js (modified) (1
> diff)
> 2) trunk/openlayers/tests/Handler/RegularPolygon.html (modified) (1 diff)
> Now when I tested the RegularPolygon.html in
> http://localhost/OpenLayers-2.7/tests/run-tests.html
> It gives one error while testing.... I am pasting the output in italics
> below:
> Handler/RegularPolygon.html: fail 1 ok 6 (detailed: fail 0 ok 25)
> test_Handler_RegularPolygon_constructor ok 3
> ok constructor calls parent with the correct control
> ok constructor calls parent with the correct callbacks
> ok regular polygon constructor calls parent with the correct options
> test_Handler_RegularPolygon_activation ok 3
> ok activate returns false if the handler was already active
> ok activate returns true if the handler was not already active
> ok deactivate returns true if the handler was active already
> test_Handler_RegularPolygon_deactivation ok 1
> ok deactivate doesn't throw an error if layer was previously destroyed
> test_Handler_RegularPolygon_four_corners ok 7
> ok correct bounds after move
> ok geometry has 5 components
> ok geometry is a polygon
> ok feature radius as set on handler
> ok correct bounds after move with a fixed radius
> ok bounds with manual radius setting
> ok bounds with manual radius setting and mousemove
> test_Handler_RegularPolygon_circle ok 7
> ok geometry has correct numbre of components
> ok correct bounds after move with fixed radius
> test_Handler_RegularPolygon_irregular ok 4
> ok correct right
> ok correct bottom
> ok correct left
> ok correct top
> test_callbacks planned 1 assertions but got 0; fail 0 ok 0
> exception: : object: 'bottom' is null or not an object
> Eric Lemoine wrote:
>> On Mon, Jan 19, 2009 at 1:52 PM, Jatin Ambasana <jatin.a at iworktech.com>
>> wrote:
>>> http://mail.google.com/mail/#label/openlayers/11eeef3d8dc95c53
>>> Hello everyone,
>>> I have added DrawFeature control to my map.
>>> Whenever it is activated it will always draw a polygon of sides 40 i.e.
>>> an
>>> approx circle.
>>> This is its code:
>>> polyOptions = {sides: 40, radius: rad, angle: 0};
>>> polygonControl = new
>>> OpenLayers.Control.DrawFeature(polygonLayer,
>>> OpenLayers.Handler.RegularPolygon,
>>> {handlerOptions: polyOptions,
>>> featureAdded:circleAdded});
>>> map.addControl(polygonControl);
>>> Now the problem is that the circleAdded function is not called when a
>>> circle
>>> is drawn on map.
>> Regards,
>> Eric
>> http://n2.nabble.com/file/n2185143/polygons.zip polygons.zip
> http://n2.nabble.com/DrawFeature-control-not-working-properly-tp2181102p2185143.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
