[OpenLayers-Users] Informations by onmouseover / alternative to WFS?
Kai Behncke Kai-Behncke at gmx.de
Fri Jun 19 11:22:34 EDT 2009
Dear users, Dear Bart,
thank you very much,
absolutely great, geatfeature-wfs seems indeed to solve the "WFS performance problem".
The wms/wfs implemented by on mapserver-file works by the way like that:
MAP
NAME           'name'
STATUS ON
EXTENT 7.9189 52.2102 8.1716 52.3467
IMAGETYPE png
UNITS dd
IMAGECOLOR 240 250 240
SIZE       700 700
 SHAPEPATH   	'/xyz/data/'
 SYMBOLSET    	'/xyz/symbols.sym'
#MAXSIZE 10000
 WEB
	TEMPLATE  'template_ol.html'
IMAGEPATH '/xyz/'
IMAGEURL   '/xyz/'
    METADATA
  	'OWS_TITLE'   'name'
	'OWS_ONLINERESOURCE'   'http://www.xyz.de/cgi-bin/mapserv?map=/path/gastronomap_ows.map'
	 "wfs_namespace_prefix"               "feature"
	'ows_SRS'       "EPSG:4326"
	"ows_contactorganization" "xyz"
      END
END
  PROJECTION
    'init=epsg:4326'
    END
LAYER
LABELMAXSCALEDENOM 10001
OFFSITE 255 255 255
LABELITEM 'name'
TOLERANCE 20
  NAME		'gastronomie_ows'
  TYPE		POINT
  STATUS	DEFAULT
  CONNECTIONTYPE postgis
  CONNECTION 'xyz'
 DATA 'the_geom_4326 from xyz'
  CLASSITEM 'gendre'
 SYMBOLSCALE 4000
TEMPLATE 'ausgabe.phtml'
DUMP TRUE
METADATA
    "ows_title" "gastronomie_ows"
    "ows_srs" "epsg:4326"
    "gml_featureid" "osm_id"
    "gml_include_items" "all"
END
CLASS
EXPRESSION /pub/
Name 'Gaststätte / Kneipe'
STYLE
SYMBOL 'pub'
MINSIZE 16
MAXSIZE 32
END
Best regards, Kai
-------- Original-Nachricht --------
> Datum: Tue, 16 Jun 2009 16:35:08 +0200
> Von: "Kai Behncke" <Kai-Behncke at gmx.de>
> An: bartvde at osgis.nl, users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Informations by onmouseover / alternative to WFS?
> Hi Bart,
> thank you for that hint.
> I have got it to run with the wms/wfs of
> layer = new OpenLayers.Layer.WMS(
> "States WMS/WFS",
> "http://demo.opengeo.org/geoserver/ows",
> {layers: 'topp:states', format: 'image/gif'}
> but I had no luck so far with my own wms/wfs.
> I use MapServer 5.4 and I have build also ONE mapfile that works as WMS
> AND WFS.
> If I do a mouseover on the areas I can see in firebug that the wfs is
> recognised, I get back e.g.
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
>    xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>    xmlns:gml="http://www.opengis.net/gml"
>    xmlns:wfs="http://www.opengis.net/wfs"
>    xmlns:ogc="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
> http://www.tourismus-maps.de/cgi-bin/mapserv54
> ?map=/home/promotion/behncke/gastronomap_wms/gastronomap_wms.map&amp;SERVICE=WFS&amp;VERSION=1.1.0&amp
> ;REQUEST=DescribeFeatureType&amp;TYPENAME=gastronomie_ows&amp;OUTPUTFORMAT=text/xml;
> subtype=gml/3.1
> .1  http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>       <gml:boundedBy>
>       	<gml:Envelope srsName="EPSG:4326">
>       		<gml:lowerCorner>8.018902 52.293344</gml:lowerCorner>
>       		<gml:upperCorner>8.022836 52.296208</gml:upperCorner>
>       	</gml:Envelope>
>       </gml:boundedBy>
>     <gml:featureMember>
>       <ms:gastronomie_ows gml:id="gastronomie_ows.7798543.000">
>         <gml:boundedBy>
>         	</gml:Envelope>
>         </gml:boundedBy>
>         <ms:msGeometry>
>           <gml:Polygon srsName="EPSG:4326">
>             <gml:exterior>
>               <gml:LinearRing>
>                 <gml:posList srsDimension="2">8.020861 52.296208 8.020993
> 52.295888 8.020546 52.295777
>  8.020815 52.294923 8.020891 52.294862 8.022112 52.294918 8.022827
> 52.294175 8.022655 52.294036 8.022836
>  52.293747 8.022221 52.293344 8.019422 52.294743 8.018902 52.295672
> 8.020861 52.296208 </gml:posList
>               </gml:LinearRing>
>             </gml:exterior>
>           </gml:Polygon>
>         </ms:msGeometry>
>         <ms:osm_id>7798543.000</ms:osm_id>
>         <ms:name></ms:name>
>         <ms:type>forest</ms:type>
>       </ms:gastronomie_ows>
>     </gml:featureMember>
> </wfs:FeatureCollection>
> .....but the hovering/highlighting does not work.
> Has anybody an idea why this can be?
> Do I need any special entries in the Mapfile?
> The typical WMS/WFS-requests work fine so far.
> Thank you very much, Kai
> > Datum: Mon, 15 Jun 2009 11:19:53 +0200 (CEST)
> > Von: bartvde at osgis.nl
> > An: "Kai Behncke" <Kai-Behncke at gmx.de>
> > CC: users at openlayers.org
> alternative      to WFS?
> > I would try and use:
> > OpenLayers.Control.GetFeature
> > examples\getfeature-wfs.html
> > Best regards,
> > Bart
> > > Dear users,
> > > I have an application where I load in 500 pois via WFS, by onmouseover
> > > some informations to that points are shown.
> > > Obviously that application is quite slow (e.g. in Internet Explorer it
> > is
> > > far too slow).
> > > Is there an alternative to WFS doing a mouseover with 500 pois?
> > > What would you recommend?
> > > GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> > > Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und Telefonanschluss
> für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
> Users mailing list
