[OpenLayers-Users] line modify crashes safari
Andreas Hocevar ahocevar at opengeo.org
Thu Jan 7 10:59:18 EST 2010
Can anyone affected by this issue please test the patch attached to
http://trac.openlayers.org/ticket/2402
I made it so the workaround only affects browsers with a userAgent
string containing "applewebkit/5". I would ask affected users to report
their user agent string. To do so, please enter
javascript:alert(navigator.userAgent)
in your browser's address bar, and report the result.
I also opened a webkit bug for the issue, see the ticket mentioned above
for a link.
Regards,
Andreas.
On 2010-01-07 03:12, Christopher Schmidt wrote:
> On Wed, Jan 06, 2010 at 11:43:37PM +0000, Wendell Turner wrote:
>> Modifying a drawn feature on this example crashes the Safari
>> browser on both Macs and Windows.
>>   http://dev.openlayers.org/releases/OpenLayers-2.8/examples/snapping.html
>> Does OpenLayers intend to support Safari for this?
> There isn't a deliberate decision not to support Safari here.
> I feel like I played with this example in Safari 3 and it worked; however,
> I'm now running Safari4, and I can confirm that it crashes.
> The fact that it crashes the browser is obviously a browser bug,
> and should probably be reported as such. However, that doesn't mean
> that we shouldn't try to improve the behavior in OpenLayers; patches welcome.
> Regards,
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
