[OpenLayers-Users] Layer.WMS.Post and loadstart-loadend event
Bart van den Eijnden bartvde at osgis.nl
Thu Jan 7 16:14:32 EST 2010
Hi Steve,
this sounds like an OpenLayers issue.
Can you please open up a Trac ticket in the OpenLayers Trac with a reproducable testcase?
The iframe code (which is used by the POST WMS layer) in OL does have some logic for the loadend event, but maybe something is going wrong somehwere, we will be able to debug once you submit a reproducable testcase. TIA.
Best regards,
Bart
On Jan 7, 2010, at 9:04 PM, Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> I'm using Layer.WMS.Post for one of my layers since the geometry comes from a complex query and GET method often doesn't work in IE.
> For this layer when I check this layer in mapfish layertree widget (Ext.treepanel) I got a progress bar that  starts but never stops.
> If I create this layer with Layer.WMS with a simple query the progress bar disapear.
> Is it because Layer.WMS.Post doesn't have a loadend event? I don't know how to verify this.
> I'm using OpenLayers.Control.LoadingPanel example
> Please tell me if this is a mapfish issue.
> Thanks
> Steve
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144
> steve.toutant at inspq.qc.ca
> http://www.inspq.qc.ca
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100107/5c3543e5/attachment.html
