[OpenLayers-Users] Layer.WMS.Post and loadstart-loadend event
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Jan 8 10:36:35 EST 2010
Thanks Bart,
I created a ticket (#2405...and 2406).
http://trac.openlayers.org/ticket/2405
I tried it twice because I got an error message saying that my attached
file was too big. It is only 284ko...
It is my first ticket, I might missed something. If the file is not
attached, tell me how to send it please.
I used the loadingPanel example. Using the layer switcher, the problen
also occurs in IE.
Steve
Bart van den Eijnden <bartvde at osgis.nl>
07/01/2010 04:14 PM
A
cc
users at openlayers.org
Objet
Re: [OpenLayers-Users] Layer.WMS.Post and loadstart-loadend event
Hi Steve,
this sounds like an OpenLayers issue.
Can you please open up a Trac ticket in the OpenLayers Trac with a
reproducable testcase?
The iframe code (which is used by the POST WMS layer) in OL does have some
logic for the loadend event, but maybe something is going wrong somehwere,
we will be able to debug once you submit a reproducable testcase. TIA.
Best regards,
Bart
On Jan 7, 2010, at 9:04 PM, Steve.Toutant at inspq.qc.ca wrote:
I'm using Layer.WMS.Post for one of my layers since the geometry comes
from a complex query and GET method often doesn't work in IE.
For this layer when I check this layer in mapfish layertree widget
(Ext.treepanel) I got a progress bar that  starts but never stops.
If I create this layer with Layer.WMS with a simple query the progress bar
disapear.
Is it because Layer.WMS.Post doesn't have a loadend event? I don't know
how to verify this.
I'm using OpenLayers.Control.LoadingPanel example
Please tell me if this is a mapfish issue.
Thanks
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100108/0f704048/attachment.html
