[OpenLayers-Users] Google + WMS = misalign
David Fawcett david.fawcett at gmail.com
Fri Jan 8 16:52:43 EST 2010
I am actually banging my head against almost the same problem right now.
If there is a solution that is 'more preferred' or cleaner than the
one pointed out by Gregor, I would love to hear about it...
David.
2010/1/8 Gregor at HostGIS <gregor at hostgis.com>:
>>> The two basemaps are from someone else's server in EPSG:23031, and the
>>> two overlays are from two more servers, one of them (Comerc) being our
>>> own. Nice alignment, indicating that our definition for 23031 must be right.
>> No, it doesn't prove that. It only shows that the transform from the other
>> servers' projection  (23031) to yours is correct. And isn't your comerc
>> server also in 23031? So no reprojection needed?
> Comerc and Catastro are different servers; if their 23031 aligns
> properly to ours, that's enough to convince me that they're correct.
> But, I was given a solution by one of the client's other contacts, and
> is it neat although slightly complex and a bit odd, and now it overlays:
> http://eixos.planol.info/google/
> The original solution was adapted from here:
> http://delta.icc.es/ideLocal/IdecServ?codi=181609&tipus=L&schema=tempc
> It seems to use elements that are not 100% kosher by OL's modern
> standards. It declares the map's projection as EPSG:4326, modifies
> OpenLayers.Layer.WMS to reproject the coordinates in the URL, and
> doesn't use sphericalMercator but does use reproject:true. A weird set
> of hacks, but apparently very effective.
> HostGIS, Open Source solutions for the global GIS community
> Greg Allensworth - SysAdmin, Programmer, GIS Person, Security
>    Network+   Server+   A+   Security+   Linux+
>    PHP   PostgreSQL   MySQL   DHTML/JavaScript/AJAX
> "No one cares if you can back up — only if you can recover."
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
