[OpenLayers-Users] How to SetUp Open Layers for an XML/WMS Service
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 29 03:05:40 EDT 2010
have a look thru the examples
http://www.openlayers.org/dev/examples/
that should be a good starting point, use view source to see how things are done
z
On 29 June 2010 13:44, Kalyan Kamepalli <kalyan.kamepalli at gmail.com> wrote:
> Hello Everyone,
> I am new to Java Script and thus Open Layers. I have an application server
> that provides a map service and many other services like select, zoom in
> zoom out.I wanted to map them on to Open layers and finally embed open
> layers on to a website. The map service is an XML based and it generates an
> XML response.I also have WMS services that respond in WMS format.
> Could someone share me the procedure to make the above process to work
> please. I know a bit of Java Script. Like how it works and how to code in it
> and the function,Object structure of it. But, I never worked on it.
> Regards,
> Kalyan
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
