[OpenLayers-Users] Problem with WFS proxy.cgi
Bart van den Eijnden bartvde at osgis.nl
Tue Mar 2 12:30:14 EST 2010
since you are running Tomcat and Geoserver, you are better off using:
http://geoserver.org/display/GEOS/GeoServer+Proxy+Extension
Best regards,
Bart
On Mar 2, 2010, at 6:26 PM, moataz Elmasry wrote:
> Hello List
> I know that this topic has been visited many times
> I'm aware of the following pages:
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#ProxyHost
> http://trac.openlayers.org/browser/trunk/openlayers/examples/proxy.cgi
> and the threads:
> http://openlayers.org/pipermail/users/2006-November/000158.html
> http://openlayers.org/pipermail/users/2009-September/013890.html
> I created a web project under eclipse and I'm running tomcat also under
> eclipse as a server. geoserver is also used standealone
> I followed the steps in the many tutorials
> 1- uncomment the cgi servlet block and the mapping block
> 2- rename the servlet jar
> 3- put the proxy.cgi file under WEB-INF/cgi
> 4- I also copied that same proxy.cgi under cgi-bin/ (i.e. two copies of
> proxy.cgi, I know its probably wrong, but I got confused with the tutorials)
> 5- both proxy.cgi are made executable with chmod
> 6- when I run localhost:8080/myproject/cgi-bin/proxy.cgi I get the
> content of that file not the openlayers page
> The file exists, only its not executed
> Any points what can I do?
> Best regards
> 5- Now when I call
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
