[OpenLayers-Users] problem cluster attributs
François Boussuges f.boussuges at gmail.com
Mon May 17 05:55:45 EDT 2010
Hello.
Actually I'm in training in the INRA (agronomicaly institute) in France.
I make a webmapping application about the genetically ressources.
I have a lot of points (sites) with different attributs, this attibuts
is load in a grid panel. this panel display all site and attributs. The
problem is that some points have the same location. For resolve this I
think use the Cluster strategy of OpenLayers. Second problem: when I
made a cluster with two (or more) points, this points disapear of my
grid panel ad the cluster is create an empty line.
Have you a solution to keep my original data in the grid panel an, when
i click on the cluster in the map, select the data point of the cluster
in the grid panel?
If you have an other solution....
With my best regards (sorry for my english).
François
